New product out from HS Tuning. Looks like we have a possible new coil upgrade available.
http://www.hstuning.com/product_info.php?products_id=5715
Discuss!!
Discuss!!
Looks like a solution to a non-existent problem.
No thanks.
Why does there need to be a problem before an upgrade/improvement can/should be made?
Because upgrading things that aren't needed to support a given power level is, at best, an inefficient use of resources.
I'm sure the stock ignition will consistently ignite a charge far more dense than 99% of people will ever throw at it.
Going from one adequate OEM coil to a slightly better one is not going to yield significant gains.
Ricers gonna rice
You probably think that catbacks add power too.Engine components is rice these days?
I could see this as a good repair option when needed. So has HS commented at all yet on the difference with these?Because HS tuning did note based on their testing there were improvements. But am waiting for them to post their findings.
And you know this because you have researched the rs3 plugs against oem I'm sure right?
Or is this an assumption you are making based on absolutely nothing?
Ricers gonna riceThis ignition stuff is getting ridiculous. Don't fix what isn't broken. I'm APR is38 FBO and run stock plugs and coils. Car runs amazing. Logs are great, I just switch out the plugs on a 8-10k interval.
Can't be worse than that intake your trying to sell. Tons of gain there also Right?
