Reversed Rear Window switch
GorData
NYC
The fix was easy. I switched out the window motor/window regulator and everything has been butter since. It wasn't a reversed wire.I guess it got programed that way at the dealership.hope everything works out for you.
kingkhan
Canada
I've got the same problem with the driverside rear window.
Push the switch down = window goes up, lift the switch up = window goes down! The one touch function of the switch is also not working. Annoying because when I put the windows down from the remote key fob that one window stays closed, when I close the others from the key fob that one windows goes down!
It started after it went into the dealer to get some minor damage fixed after some stupid woman drove into me.
The dealer is having problems trying to work out the cause and a fix for it, they've had it a week and I'm driving around in their loan car.... a VW Fox:thumbdown:
Probably a long shot, but what was the resolution? I have a 2008 GTI that has the same problem. The rear right window works in reverse on both the driver switch and the door switch. This definitely seems like a software issue vs hardware.
I looked into the rear right door module with OBD11, and I'm not sure what to change in order to affect window functionality.
DunnRight
Portland, OR
2007 GTI
I am having the same issue on my 07 GTI. Back right window. Did you ever find a fix?
kingkhan
Canada
Nope, I'm planning on getting a replacement window module from the junk yard when things start to return to normal. I couldn't see anything with my OBD11 that was wrong.
I suspect it's an issue with the module's Firmware that only the dealer will be able to fix.
kingkhan
Canada
Well I'm stumped on this issue.
I ordered a replacement window motor from Europe off of a Skoda (part number is the same). There is the door control module that comes attached to the window motor. I swapped the whole assembly to the one I ordered and the window is still reversed. This rules out an issue with my module unless the one I ordered was also experiencing the same issue, but I find that a bit hard to believe.
