Resonator Delete Facts & FAQ
Cbus mkv
Lowcally Famous
Dayton, Ohio
anyone know if the 42dd will fit perfectly with my setup,
ebay 3inch catless downpipe
apr quad back catback
...i know i have apr and i shouldn't change it but the resonator is huge and hits the ground due to how low i am
amouse
malaysia
im running on 3" catless, stock resonator with r32 milltek backbox and i've lost the DSG farting sound.. :( how can i get it back?
strubby
Daytona Beach
07 GTI DSG
Hey guys, on my '07 GTI is the resonator straight through or chambered? I plan on doing a DP and like the sound of it combined with the stock exhaust but want to keep it as deep toned as possible. I'm wondering if removing the OEM resonator and replacing with an aftermarket straight through would be the way to go? Maybe I should just wait until the DP is on, then decide. I'm been tossing around the idea of replacing the OEM muffler with a Magnaflow and adding an aftermarket resonator as well, I JUST DON"T KNOW! haha.
For now, just wondering if an aftermarket resonator would be any different than the OEM.
Maximum6
FASTER
in heaven
When you have a shop weld in a pipe for the resonator..
does it matter the diameter of the pipe?
I think stock is like 2.25?
Also do they need hangers for the pipe..or does welding hold the pipe just fine?
jetro_b73tz
GTI = Got Turbo Inside
jakarta, Indonesia
GTI MK5
I just did the delete but my car still sounds the same also would it matter if the pipe they put looks smaller then the rest
Are you sure that you delete the resonator?? not the catalyc???
the OEM pipe is nearly 2.3" diameter,, the resonator located after the S shaped junction on your exhaust pipeline,,
just buy any universal resonator that has the same size as your 3" APR pipe, or you could remove itu,, if you remove it then the sound will increase a lot,, because APR quad catback is not RSC technology,,
just remove the resonator and it will magically come back bro, hehe
Wait until you install the DP,, so you'll notice the different,, and if you think that it's still not too loud, then you can do resonator removal,,
The OEM reson is chambered,
Off course if you change the reson to the straight through one, then the sound will increase.
yes,, the stock is about 2.25" ,, actually it's not really matter if you change it to 2.5" ,, but it's better to change to bigger pipe then change to 2",
mushages
Oman
07 GTi DSG
WARNING : i did the res delete and i have ATP 3" downpipe the sound is too F*cking LOUD!!! not as what u hear in the videos :p but i decided to keep it this way until i get pulled by the police then i will put it back
Stampedevxl
RACECAR > STANCECAR
Lutz fl
really?
really? cause i have pretty much the same setup (except the gli has a smaller muffler) and its not that loud/ from inside at least i havent heard it drive by.
Maximum6
FASTER
in heaven
got mine done. Gonna check what it looks like tomorrow.
But it is Friggin loud. I thought it might be a bit ricerish...
3inch catless dp with resonator delete here.
What i like is the unburnt fuel popping noises.
3514R32
Alaska
I bought my car with the resonator already taken off and a flapper mod. I like the sound of it. When I had my STi that also had the resonator taken off and that sounded awesome.
Naughty picture!
GTIZA
NOOB
Aurora, Ont.
07 TR GTI
someone convince me to get this done! i've been checking youtube and the sounds of the res delete varies drastically from vid to vid. i don't wanna drop the cash on a new exhaust but i also don't want to sound like a fkn knob. i'm hoping for a deeper tone...?
