gtiwop
- San Diego, CA
I am about to undertake the job and I have two questions for you guys and yes I've read the DIY.
1- After releasing the pressure by bleeding the bleeder valve I read that it has to be removed. What's the point of that? The valve is not connected to anything except the FP body so why remove it?
2- When disconnecting the fuel line I am supposed to leave the (internal?) rubber line connected so that it will be easy to reconnect. What I cannot figure out is how the fuel line, even with the metal part disconnect, is going to have enough play, since the metal part is still over the rubber line, to allow the pump to move back without putting a kink in the metal tube.
I'm a noob at this, please have patience. Thanks for the time and help.:bow:
