Rain Tray/ Windshield Cowl and Fresh Air Intake Manifold
crazylegs
Hello All,
I currently have a crack on the lip of the current Windshield cowl, where that plastic rain tray meets the glass. This crack is causing the rain tray to have a slight drop or sag on the passenger corner. I noticed a plastic cracking noise when it gets colder outside and I also noticed a little bit of water getting into my Pollen Air Filter.
I will be replacing the entire windshield cowl with the below kit...
https://www.ecstuning.com/b-genuine...ndshield-cowl-cover-refresh-kit/1k1819415bkt/
I will be replacing the fresh air intake manifold, which I am assuming the gasket has a slight failure with the part below...
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/manifold/1k0815479b/
Will there be any other plastic bits or pieces that I need to be concerned about that is under the raintray and around the area where the fresh air enters the manifold?
GTI's
MD
You covered everything........good time to clean the cowl area and check the sunroof drain nipples.
crazylegs
GTI's, I do not have a sunroof so I don't think I will have to check the nipples :p
