Thanks for the explanation. What happens then when the auto hold is off and you stop on a hill? Will the car roll backwards if the brakes are not applied? I assume not, but why/how? Also with the auto hold function on, and the start / stop system switching the engine off at a stop, I noticed that the engine restarts as soon as you accelerate, whereas when auto hold is off, the engine restarts as soon as the foot depresses the brake pedal. Just trying to understand my car...
So I turned auto hold on straight away when I got my car and have never actually turned it off; but based on my experience with a DSG MK6 this is what I'd expect to happen:
I'd expect the hill hold assist would kick in when you take your foot off the brake, hold the car in place for a couple of seconds giving you time to switch your foot to the accelerator: unless its a monumentally steep hill I'd expect that it would then begin to slowly creep forward, I assume if its really steep and you've packed your car full of stolen gold then it would start rolling backwards if you didn't hit the gas.
Yeah, and if you just lightly tap the accelerator you can get the engine to restart but the autohold will stay on so you don't start creeping forward but your even more ready to jump out into fast moving traffic.
Depresses, as in un-presses? that would make sense to me, if you have auto hold off, and you take your foot off the brake then the car should start moving forward, thus the engine needs to be started; with autohold on you take your foot off the brake the car knows its still not been actively told to start moving forward (you've not yet press down hard enough to unlock the autohold) so it just leaves the engine off.
A little bit of guess work in my answers seeing as I just never switch autohold off.
I have had a couple of instances where my car did start rolling backward on a hill (don't totally remember the circumstances): only reason I really noticed was because the parking sensors flashed up as they do when you put the car into reverse; in reality it maybe moved backwards an inch or 2 if that...
