Whitedemon
- Miami, FL
One more question (may have a couple more before I give you my full set of recommendations) - What gear were you in when running WM on with T7?
All of my WOT runs I do them on 3rd gear
Dialing it in means adding just enough WM mix to eliminate any timing loss but no more than that. If you spray too much it can cause a loss of power all the way to misfiring depending on how far you overshoot your need.
Try switching to the 250. Set START at 4 and MAX at 30 and run a log with WM on. Start there and lets see if we can clean up your timing losses and turn them to zeros. To be sure we have not added too much once we get to zeros we will again adjust spray until we just begin to see some timing being pulled and then add just enough spray back in to go to all zeros.
Sounds like we are going in the right direction. Logs will tell you when you have actually arrived at your desired destination.
So by setting MAX out further than your actual max boost we are keeping the pump from pumping at full pressure and reducing spray. The downside of turning down the pump on a larger jet than we need is that atomization of the spray will not be as good as it would be under full pressure using a smaller jet.
In your case, you have the fuel required by the tune so you are just after the best cooling you can get and you want the most evaporation you can get. In general I have had better results by placing the cooling jet further back in the stream (right after intercooler) rather than where you have it. My concern with a larger jet in that location is that you may be spraying liquid directly onto MAP with that larger jet running on reduced pressure. It would be best to try a smaller jet and be able to use the full pressure of the pump against the already higher pressure of air in the tube especially with the jet in its current location.
Column1 | Column2 | Column3 | Column4 | Column5 | Column6 | Column7 | Column8 | Column9 | Column10 | Column11 | Column12 | Column13 | Column14 | Column15 | Column16 |
Group A: | '020 | Group B: | '115 | Group C: | '014 | ||||||||||
Timing Retardation | Timing Retardation | Timing Retardation | Timing Retardation | Engine Speed | Engine Load | Boost Pressure | Boost Pressure | Engine Speed | Engine Load | Misfire Counter | Misfire | ||||
TIME | Cylinder 1 | Cylinder 2 | Cylinder 3 | Cylinder 4 | TIME | (G28) | (specified) | (actual) | TIME | (G28) | Recognition | ||||
Marker | STAMP | °KW | °KW | °KW | °KW | STAMP | /min | % | mbar | mbar | STAMP | /min | % | ||
0.25 | 0 | 0 | 0 | 0 | 0.01 | 2200 | 72.2 | 1750 | 1110 | 0.13 | 2240 | 76.7 | 0 | Enabled | |
0.63 | 0 | 0 | 0 | 0 | 0.37 | 2280 | 78.9 | 2140 | 1210 | 0.5 | 2320 | 81.2 | 0 | Enabled | |
1.02 | 0 | 0 | 0 | 0 | 0.77 | 2400 | 86.5 | 2210 | 1330 | 0.89 | 2440 | 89.5 | 0 | Enabled | |
1.39 | 0 | 0 | 0 | 0 | 1.14 | 2520 | 94.7 | 2250 | 1440 | 1.27 | 2600 | 97.7 | 0 | Enabled | |
1.77 | 0 | 0 | 0 | 0 | 1.52 | 2680 | 106.8 | 2210 | 1560 | 1.64 | 2720 | 111.3 | 0 | Enabled | |
2.14 | 0 | 0 | 0 | 0 | 1.89 | 2840 | 123.3 | 2160 | 1750 | 2.02 | 2920 | 130.8 | 0 | Enabled | |
2.52 | 0 | 0 | 0 | 0 | 2.27 | 3040 | 146.6 | 2270 | 2060 | 2.39 | 3120 | 155.6 | 0 | Enabled | |
2.89 | 0 | 0 | 0 | 0 | 2.64 | 3280 | 166.9 | 2440 | 2270 | 2.77 | 3360 | 171.4 | 0 | Enabled | |
3.27 | 0 | 0 | 0 | 0 | 3.02 | 3520 | 180.5 | 2540 | 2440 | 3.14 | 3600 | 184.2 | 0 | Enabled | |
3.64 | 0 | 0 | 0 | 0 | 3.39 | 3760 | 188.7 | 2540 | 2490 | 3.52 | 3840 | 190.2 | 0 | Enabled | |
4.02 | 0 | 0 | 0 | 0 | 3.77 | 4000 | 191.7 | 2540 | 2500 | 3.89 | 4120 | 191.7 | 0 | Enabled | |
4.39 | 0 | 0 | 0 | 0 | 4.14 | 4280 | 191.7 | 2540 | 2500 | 4.27 | 4400 | 191.7 | 0 | Enabled | |
4.78 | 0 | 0 | 0 | 0 | 4.52 | 4560 | 191.7 | 2540 | 2510 | 4.64 | 4640 | 191.7 | 0 | Enabled | |
5.16 | 0 | 0 | 0 | 0 | 4.91 | 4800 | 191.7 | 2540 | 2500 | 5.03 | 4840 | 191.7 | 0 | Enabled | |
5.53 | 0 | 0 | 0 | 0 | 5.28 | 5000 | 191.7 | 2530 | 2520 | 5.41 | 5160 | 191.7 | 0 | Enabled | |
5.91 | 0 | 0 | 0 | 0 | 5.66 | 5240 | 191.7 | 2500 | 2520 | 5.78 | 5320 | 191.7 | 0 | Enabled | |
6.28 | 0 | 0 | 0 | 0 | 6.03 | 5440 | 191.7 | 2470 | 2450 | 6.16 | 5520 | 191.7 | 0 | Enabled | |
6.66 | 0 | 0 | 0 | 0 | 6.41 | 5680 | 191.7 | 2440 | 2410 | 6.54 | 5760 | 191.7 | 0 | Enabled | |
7.04 | 0 | 0 | 0 | 0 | 6.78 | 5840 | 191.7 | 2420 | 2440 | 6.91 | 5960 | 191.7 | 0 | Enabled |
0.26 | 0 | 0 | 0 | 0 | 0.01 | 2240 | 82.7 | 2030 | 1330 | 0.13 | 2280 | 85.7 | 1 | Enabled | |
0.63 | 0 | 0 | 0 | 0 | 0.38 | 2360 | 90.2 | 2210 | 1390 | 0.5 | 2400 | 92.5 | 1 | Enabled | |
1.01 | 0 | 0 | 0 | 0 | 0.75 | 2480 | 96.2 | 2290 | 1470 | 0.88 | 2520 | 98.5 | 1 | Enabled | |
1.39 | 0 | 0 | 0 | 0 | 1.14 | 2640 | 105.3 | 2220 | 1560 | 1.27 | 2680 | 109 | 1 | Enabled | |
1.77 | 0 | 0 | 0 | 0 | 1.52 | 2800 | 118.8 | 2200 | 1710 | 1.64 | 2840 | 124.1 | 1 | Enabled | |
2.15 | 0 | 0 | 0 | 0 | 1.9 | 2960 | 137.6 | 2260 | 1960 | 2.02 | 3080 | 147.4 | 1 | Enabled | |
2.52 | 0 | 0 | 0 | 0 | 2.27 | 3200 | 156.4 | 2330 | 2180 | 2.39 | 3280 | 161.7 | 1 | Enabled | |
2.89 | 0 | 0 | 0 | 0 | 2.64 | 3400 | 170.7 | 2520 | 2350 | 2.77 | 3520 | 175.2 | 1 | Enabled | |
3.27 | 0 | 0 | -0.8 | 0 | 3.02 | 3640 | 181.2 | 2540 | 2450 | 3.14 | 3720 | 183.5 | 1 | Enabled | |
3.65 | 0 | 0 | 0 | 0 | 3.39 | 3880 | 187.2 | 2540 | 2490 | 3.52 | 3960 | 189.5 | 1 | Enabled | |
4.03 | 0 | 0 | 0 | 0 | 3.77 | 4120 | 190.2 | 2540 | 2500 | 3.89 | 4200 | 190.2 | 1 | Enabled | |
4.41 | 0 | 0 | 0 | 0 | 4.16 | 4400 | 189.5 | 2550 | 2490 | 4.28 | 4480 | 188.7 | 1 | Enabled | |
4.79 | 0 | 0 | 0 | 0 | 4.53 | 4600 | 191 | 2550 | 2500 | 4.66 | 4680 | 191.7 | 1 | Enabled | |
5.16 | 0 | 0 | 0 | 0 | 4.91 | 4960 | 191.7 | 2530 | 2500 | 5.04 | 5000 | 191.7 | 1 | Enabled | |
5.54 | 0 | 0 | 0 | 0 | 5.28 | 5120 | 191.7 | 2520 | 2520 | 5.41 | 5200 | 191.7 | 1 | Enabled | |
5.91 | 0 | 0 | 0 | 0 | 5.66 | 5320 | 191.7 | 2500 | 2530 | 5.78 | 5400 | 191.7 | 1 | Enabled | |
6.29 | 0 | 0 | 0 | 0 | 6.03 | 5520 | 191.7 | 2470 | 2450 | 6.16 | 5600 | 191.7 | 1 | Enabled | |
6.66 | 0 | 0 | 0 | 0 | 6.41 | 5720 | 191.7 | 2440 | 2410 | 6.54 | 5800 | 191.7 | 1 | Enabled | |
7.05 | 0 | 0 | 0 | 0 | 6.78 | 5920 | 191.7 | 2420 | 2410 | 6.91 | 5960 | 191.7 | 1 | Enabled | |
7.42 | 0 | 0 | 0 | 0 | 7.18 | 6120 | 191.7 | 2390 | 2390 | 7.3 | 6200 | 191.7 | 1 | Enabled | |
7.8 | 0 | 0 | 0 | 0 | 7.55 | 6320 | 191.7 | 2380 | 2330 | 7.68 | 6320 | 191.7 | 1 | Enabled |
Group A: | '015 | Group B: | '020 | Group C: | '115 | ||||||||||
Misfire Counter | Misfire Counter | Misfire Counter | Misfire | Timing Retardation | Timing Retardation | Timing Retardation | Timing Retardation | Engine Speed | Engine Load | Boost Pressure | Boost Pressure | ||||
TIME | Cylinder 1 | Cylinder 2 | Cylinder 3 | Recognition | TIME | Cylinder 1 | Cylinder 2 | Cylinder 3 | Cylinder 4 | TIME | (G28) | (specified) | (actual) | ||
Marker | STAMP | STAMP | °KW | °KW | °KW | °KW | STAMP | /min | % | mbar | mbar | ||||
0.01 | 0 | 0 | 0 | Enabled | 0.13 | 0 | 0 | 0 | 0 | 0.26 | 2120 | 83.5 | 2050 | 1290 | |
0.39 | 0 | 0 | 0 | Enabled | 0.51 | 0 | 0 | 0 | 0 | 0.63 | 2240 | 86.5 | 2130 | 1330 | |
0.76 | 0 | 0 | 0 | Enabled | 0.88 | 0 | 0 | 0 | 0 | 1.01 | 2400 | 91 | 2200 | 1390 | |
1.13 | 0 | 0 | 0 | Enabled | 1.26 | 0 | 0 | 0 | 0 | 1.38 | 2520 | 95.5 | 2230 | 1460 | |
1.51 | 0 | 0 | 0 | Enabled | 1.63 | 0 | 0 | 0 | 0 | 1.76 | 2640 | 104.5 | 2200 | 1550 | |
1.88 | 0 | 0 | 0 | Enabled | 2.01 | 0 | 0 | 0 | 0 | 2.13 | 2840 | 116.5 | 2160 | 1680 | |
2.26 | 0 | 0 | 0 | Enabled | 2.38 | 0 | 0 | 0 | -3 | 2.51 | 3000 | 134.6 | 2240 | 1920 | |
2.63 | 0 | 0 | 0 | Enabled | 2.76 | 0 | -3 | 0 | -3 | 2.88 | 3200 | 154.1 | 2300 | 2140 | |
3.01 | 0 | 0 | 0 | Enabled | 3.13 | 0 | -3 | 0 | -3 | 3.26 | 3440 | 165.4 | 2490 | 2290 | |
3.38 | 0 | 0 | 0 | Enabled | 3.51 | 0 | -3 | 0 | -3 | 3.63 | 3680 | 178.9 | 2520 | 2430 | |
3.76 | 0 | 0 | 0 | Enabled | 3.89 | 0 | 0 | -0.8 | 0 | 4.01 | 3920 | 185.7 | 2540 | 2470 | |
4.14 | 0 | 0 | 0 | Enabled | 4.28 | 0 | 0 | -0.8 | 0 | 4.4 | 4160 | 187.2 | 2540 | 2490 | |
4.52 | 0 | 0 | 0 | Enabled | 4.65 | 0 | 0 | -0.8 | 0 | 4.78 | 4440 | 188.7 | 2540 | 2510 | |
4.9 | 0 | 0 | 0 | Enabled | 5.03 | 0 | 0 | 0 | 0 | 5.15 | 4680 | 188.7 | 2540 | 2500 | |
5.27 | 0 | 0 | 0 | Enabled | 5.4 | 0 | 0 | 0 | 0 | 5.52 | 4920 | 191.7 | 2540 | 2510 | |
5.65 | 0 | 0 | 0 | Enabled | 5.77 | 0 | 0 | 0 | 0 | 5.9 | 5160 | 191.7 | 2530 | 2530 | |
6.03 | 0 | 0 | 0 | Enabled | 6.15 | 0 | 0 | 0 | 0 | 6.28 | 5360 | 191.7 | 2500 | 2530 | |
6.4 | 0 | 0 | 0 | Enabled | 6.53 | 0 | 0 | 0 | 0 | 6.65 | 5560 | 191.7 | 2480 | 2470 | |
6.77 | 0 | 0 | 0 | Enabled | 6.9 | 0 | 0 | 0 | 0 | 7.02 | 5760 | 191.7 | 2450 | 2420 | |
7.15 | 0 | 0 | 0 | Enabled | 7.27 | 0 | 0 | 0 | 0 | 7.4 | 5960 | 191.7 | 2420 | 2400 | |
7.52 | 0 | 0 | 0 | Enabled | 7.65 | 0 | 0 | 0 | 0 | 7.77 | 6160 | 191.7 | 2410 | 2380 | |
7.9 | 0 | 0 | 0 | Enabled | 8.03 | 0 | 0 | 0 | 0 | 8.17 | 6320 | 191.7 | 2390 | 2360 |
Group A: | '015 | Group B: | '016 | Group C: | '020 | ||||||||||
Misfire Counter | Misfire Counter | Misfire Counter | Misfire | Misfire Counter | Misfire | Timing Retardation | Timing Retardation | Timing Retardation | Timing Retardation | ||||||
TIME | Cylinder 1 | Cylinder 2 | Cylinder 3 | Recognition | TIME | Cylinder 4 | Recognition | TIME | Cylinder 1 | Cylinder 2 | Cylinder 3 | Cylinder 4 | |||
Marker | STAMP | STAMP | STAMP | °KW | °KW | °KW | °KW | ||||||||
0.06 | 0 | 0 | 0 | Enabled | 0.19 | 0 | Enabled | 0.31 | 0 | 0 | 0 | 0 | |||
0.44 | 0 | 0 | 0 | Enabled | 0.56 | 0 | Enabled | 0.69 | 0 | 0 | 0 | 0 | |||
0.81 | 0 | 0 | 0 | Enabled | 0.94 | 0 | Enabled | 1.06 | 0 | 0 | 0 | 0 | |||
1.19 | 0 | 0 | 0 | Enabled | 1.31 | 0 | Enabled | 1.44 | 0 | 0 | 0 | 0 | |||
1.56 | 0 | 0 | 0 | Enabled | 1.7 | 0 | Enabled | 1.82 | 0 | 0 | 0 | 0 | |||
1.96 | 0 | 0 | 0 | Enabled | 2.08 | 0 | Enabled | 2.2 | 0 | 0 | 0 | 0 | |||
2.33 | 0 | 0 | 0 | Enabled | 2.45 | 0 | Enabled | 2.58 | 0 | 0 | 0 | 0 | |||
2.7 | 0 | 0 | 0 | Enabled | 2.83 | 0 | Enabled | 2.95 | 0 | 0 | 0 | 0 | |||
3.08 | 0 | 0 | 0 | Enabled | 3.2 | 0 | Enabled | 3.33 | 0 | 0 | 0 | 0 | |||
3.45 | 0 | 0 | 0 | Enabled | 3.58 | 0 | Enabled | 3.7 | 0 | 0 | 0 | 0 | |||
3.83 | 0 | 0 | 0 | Enabled | 3.95 | 0 | Enabled | 4.07 | 0 | 0 | 0 | 0 | |||
4.21 | 0 | 0 | 0 | Enabled | 4.33 | 0 | Enabled | 4.45 | 0 | 0 | 0 | 0 | |||
4.58 | 0 | 0 | 0 | Enabled | 4.72 | 0 | Enabled | 4.84 | 0 | 0 | 0 | 0 | |||
4.97 | 0 | 0 | 0 | Enabled | 5.09 | 0 | Enabled | 5.22 | 0 | 0 | 0 | 0 | |||
5.34 | 0 | 0 | 0 | Enabled | 5.47 | 0 | Enabled | 5.59 | 0 | 0 | 0 | 0 | |||
5.72 | 0 | 0 | 0 | Enabled | 5.84 | 0 | Enabled | 5.97 | 0 | 0 | 0 | 0 | |||
6.1 | 0 | 0 | 0 | Enabled | 6.22 | 0 | Enabled | 6.34 | 0 | 0 | 0 | 0 | |||
6.47 | 0 | 0 | 0 | Enabled | 6.59 | 0 | Enabled | 6.72 | 0 | 0 | 0 | 0 | |||
6.84 | 0 | 0 | 0 | Enabled | 6.97 | 0 | Enabled | 7.1 | 0 | 0 | 0 | 0 | |||
7.22 | 0 | 0 | 0 | Enabled | 7.35 | 0 | Enabled | 7.47 | 0 | 0 | 0 | 0 | |||
7.59 | 0 | 0 | 0 | Enabled | 7.74 | 0 | Enabled | 7.86 | 0 | 0 | 0 | 0 |
Yes, I would go with the smaller jet and log.
0.11 | 0 | 0 | 0 | 0 | 0.01 | 2160 | 86.5 | 2090 | 1330 | 0.06 | 2160 | 87.2 | 1 | Enabled | |
0.26 | 0 | 0 | 0 | 0 | 0.17 | 2200 | 88 | 2160 | 1350 | 0.22 | 2200 | 88 | 1 | Enabled | |
0.4 | 0 | 0 | 0 | 0 | 0.31 | 2240 | 88.7 | 2160 | 1370 | 0.35 | 2280 | 89.5 | 1 | Enabled | |
0.54 | 0 | 0 | 0 | 0 | 0.45 | 2280 | 90.2 | 2180 | 1380 | 0.5 | 2320 | 91 | 1 | Enabled | |
0.68 | 0 | 0 | 0 | 0 | 0.6 | 2320 | 92.5 | 2240 | 1410 | 0.64 | 2360 | 92.5 | 1 | Enabled | |
0.82 | 0 | 0 | 0 | 0 | 0.73 | 2360 | 94 | 2240 | 1440 | 0.78 | 2400 | 94.7 | 1 | Enabled | |
0.97 | 0 | 0 | 0 | 0 | 0.87 | 2440 | 95.5 | 2300 | 1460 | 0.91 | 2440 | 96.2 | 1 | Enabled | |
1.11 | 0 | 0 | 0 | 0 | 1.01 | 2480 | 97.7 | 2300 | 1490 | 1.07 | 2520 | 98.5 | 1 | Enabled | |
1.25 | 0 | 0 | 0 | 0 | 1.15 | 2520 | 100.8 | 2320 | 1530 | 1.2 | 2560 | 101.5 | 1 | Enabled | |
1.38 | 0 | 0 | 0 | 0 | 1.29 | 2600 | 103.8 | 2320 | 1570 | 1.34 | 2600 | 104.5 | 1 | Enabled | |
1.53 | 0 | 0 | 0 | 0 | 1.44 | 2640 | 107.5 | 2290 | 1600 | 1.48 | 2680 | 109 | 1 | Enabled | |
1.67 | 0 | 0 | 0 | 0 | 1.58 | 2720 | 112 | 2260 | 1640 | 1.62 | 2720 | 113.5 | 1 | Enabled | |
1.81 | 0 | 0 | 0 | 0 | 1.71 | 2760 | 117.3 | 2200 | 1700 | 1.77 | 2800 | 119.5 | 1 | Enabled | |
1.95 | 0 | 0 | 0 | 0 | 1.86 | 2840 | 122.6 | 2200 | 1770 | 1.9 | 2840 | 125.6 | 1 | Enabled | |
2.09 | 0 | 0 | 0 | 0 | 1.99 | 2880 | 130.1 | 2240 | 1860 | 2.04 | 2920 | 133.1 | 1 | Enabled | |
2.23 | 0 | 0 | 0 | 0 | 2.13 | 2960 | 139.1 | 2280 | 1960 | 2.18 | 3000 | 142.1 | 1 | Enabled | |
2.37 | 0 | 0 | 0 | 0 | 2.27 | 3040 | 148.1 | 2300 | 2090 | 2.32 | 3080 | 151.1 | 1 | Enabled | |
2.51 | 0 | 0 | 0 | 0 | 2.42 | 3120 | 154.9 | 2370 | 2140 | 2.46 | 3160 | 155.6 | 1 | Enabled | |
2.65 | 0 | 0 | 0 | 0 | 2.56 | 3240 | 159.4 | 2390 | 2210 | 2.6 | 3240 | 160.9 | 1 | Enabled | |
2.79 | 0 | 0 | 0 | 0 | 2.7 | 3280 | 164.7 | 2480 | 2270 | 2.75 | 3320 | 165.4 | 1 | Enabled | |
2.94 | 0 | 0 | 0 | 0 | 2.84 | 3400 | 169.2 | 2530 | 2330 | 2.89 | 3400 | 170.7 | 1 | Enabled | |
3.09 | 0 | 0 | 0 | 0 | 2.99 | 3440 | 173.7 | 2540 | 2370 | 3.04 | 3520 | 175.2 | 1 | Enabled | |
3.23 | 0 | 0 | 0 | 0 | 3.13 | 3560 | 178.2 | 2540 | 2410 | 3.18 | 3600 | 179.7 | 1 | Enabled | |
3.37 | 0 | 0 | 0 | 0 | 3.27 | 3640 | 179.7 | 2540 | 2430 | 3.32 | 3680 | 180.5 | 1 | Enabled | |
3.51 | 0 | 0 | 0 | 0 | 3.42 | 3760 | 182.7 | 2540 | 2440 | 3.46 | 3760 | 183.5 | 1 | Enabled | |
3.65 | 0 | 0 | 0 | 0 | 3.56 | 3840 | 185.7 | 2540 | 2470 | 3.6 | 3840 | 186.5 | 1 | Enabled | |
3.79 | 0 | 0 | 0 | 0 | 3.69 | 3920 | 188 | 2540 | 2480 | 3.75 | 3960 | 188.7 | 1 | Enabled | |
3.95 | 0 | 0 | 0 | 0 | 3.83 | 4000 | 189.5 | 2540 | 2480 | 3.9 | 4040 | 189.5 | 1 | Enabled | |
4.09 | 0 | 0 | 0 | 0 | 3.99 | 4120 | 190.2 | 2540 | 2500 | 4.04 | 4160 | 190.2 | 1 | Enabled | |
4.23 | 0 | 0 | 0 | 0 | 4.14 | 4200 | 189.5 | 2540 | 2480 | 4.18 | 4240 | 189.5 | 1 | Enabled | |
4.36 | 0 | 0 | 0 | 0 | 4.28 | 4320 | 189.5 | 2540 | 2490 | 4.32 | 4320 | 188.7 | 1 | Enabled | |
4.52 | 0 | 0 | 0 | 0 | 4.42 | 4400 | 188.7 | 2540 | 2480 | 4.47 | 4440 | 189.5 | 1 | Enabled | |
4.65 | 0 | 0 | 0 | 0 | 4.56 | 4520 | 189.5 | 2540 | 2480 | 4.6 | 4560 | 188.7 | 1 | Enabled | |
4.79 | 0 | 0 | 0 | 0 | 4.7 | 4600 | 189.5 | 2540 | 2480 | 4.74 | 4640 | 189.5 | 1 | Enabled | |
4.95 | 0 | 0 | 0 | 0 | 4.84 | 4720 | 190.2 | 2540 | 2480 | 4.9 | 4760 | 191 | 1 | Enabled | |
5.09 | 0 | 0 | 0 | 0 | 5 | 4800 | 191.7 | 2540 | 2480 | 5.04 | 4840 | 191.7 | 1 | Enabled | |
5.23 | 0 | 0 | 0 | 0 | 5.14 | 4880 | 191.7 | 2540 | 2490 | 5.19 | 4920 | 191.7 | 1 | Enabled | |
5.37 | 0 | 0 | 0 | 0 | 5.28 | 4960 | 191.7 | 2540 | 2500 | 5.32 | 4960 | 191.7 | 1 | Enabled | |
5.51 | 0 | 0 | 0 | 0 | 5.42 | 5040 | 191.7 | 2530 | 2520 | 5.46 | 5080 | 191.7 | 1 | Enabled | |
5.65 | 0 | 0 | 0 | 0 | 5.55 | 5120 | 191.7 | 2520 | 2520 | 5.61 | 5120 | 191.7 | 1 | Enabled | |
5.79 | 0 | 0 | 0 | 0 | 5.7 | 5200 | 191.7 | 2510 | 2540 | 5.74 | 5200 | 191.7 | 1 | Enabled | |
5.93 | 0 | 0 | 0 | 0 | 5.84 | 5280 | 191.7 | 2510 | 2540 | 5.89 | 5320 | 191.7 | 1 | Enabled | |
6.08 | 0 | 0 | 0 | 0 | 5.98 | 5320 | 191.7 | 2500 | 2530 | 6.03 | 5400 | 191.7 | 0 | Enabled | |
6.22 | 0 | 0 | 0 | 0 | 6.12 | 5440 | 191.7 | 2480 | 2520 | 6.17 | 5440 | 191.7 | 0 | Enabled | |
6.36 | 0 | 0 | 0 | 0 | 6.27 | 5520 | 191.7 | 2480 | 2500 | 6.31 | 5520 | 191.7 | 0 | Enabled | |
6.5 | 0 | 0 | 0 | 0 | 6.4 | 5600 | 191.7 | 2470 | 2450 | 6.45 | 5600 | 191.7 | 0 | Enabled | |
6.65 | 0 | 0 | 0 | 0 | 6.55 | 5640 | 191.7 | 2460 | 2430 | 6.61 | 5680 | 191.7 | 0 | Enabled | |
6.8 | 0 | 0 | 0 | 0 | 6.7 | 5720 | 191.7 | 2450 | 2400 | 6.75 | 5760 | 191.7 | 0 | Enabled | |
6.94 | 0 | 0 | 0 | 0 | 6.84 | 5800 | 191.7 | 2440 | 2400 | 6.89 | 5800 | 191.7 | 0 | Enabled | |
7.08 | 0 | 0 | 0 | 0 | 6.98 | 5880 | 191.7 | 2430 | 2390 | 7.03 | 5920 | 191.7 | 0 | Enabled | |
7.21 | 0 | 0 | 0 | 0 | 7.13 | 6000 | 191.7 | 2410 | 2400 | 7.17 | 6000 | 191.7 | 0 | Enabled | |
7.35 | 0 | 0 | 0 | 0 | 7.26 | 6000 | 191.7 | 2410 | 2400 | 7.31 | 6040 | 191.7 | 0 | Enabled | |
7.5 | 0 | 0 | 0 | 0 | 7.4 | 6080 | 191.7 | 2410 | 2400 | 7.45 | 6080 | 191.7 | 0 | Enabled | |
7.64 | 0 | 0 | 0 | 0 | 7.55 | 6160 | 191.7 | 2400 | 2380 | 7.59 | 6160 | 191.7 | 0 | Enabled | |
7.79 | 0 | 0 | 0 | 0 | 7.7 | 6240 | 191.7 | 2400 | 2380 | 7.75 | 6240 | 191.7 | 0 | Enabled | |
7.95 | 0 | 0 | 0 | 0 | 7.84 | 6280 | 191.7 | 2390 | 2370 | 7.89 | 6320 | 191.7 | 0 | Enabled | |
8.11 | 0 | 0 | 0 | 0 | 8 | 6360 | 191.7 | 2390 | 2380 | 8.05 | 6400 | 191.7 | 0 | Enabled | |
8.25 | 0 | 0 | 0 | 0 | 8.16 | 6560 | 191.7 | 1830 | 2350 | 8.2 | 6560 | 191.7 | 0 | Enabled | |
8.39 | 0 | 0 | 0 | 0 | 8.29 | 6480 | 165.4 | 1170 | 2550 | 8.34 | 6480 | 130.8 | 0 | Enabled |
0.01 | 0 | 0 | 0 | 0 | 0.05 | 2560 | 24.1 | 390 | 1280 | 0.1 | 2560 | 22.6 | 1 | Enabled | |
0.15 | 0 | 0 | 0 | 0 | 0.2 | 2560 | 32.3 | 1870 | 1160 | 0.24 | 2640 | 68.4 | 1 | Enabled | |
0.29 | 0 | 0 | 0 | 0 | 0.34 | 2600 | 78.2 | 2250 | 1200 | 0.39 | 2640 | 79.7 | 1 | Enabled | |
0.44 | 0 | 0 | 0 | 0 | 0.48 | 2640 | 83.5 | 2190 | 1260 | 0.52 | 2640 | 85.7 | 1 | Enabled | |
0.57 | 0 | 0 | 0 | 0 | 0.62 | 2720 | 90.2 | 2200 | 1330 | 0.66 | 2720 | 91.7 | 1 | Enabled | |
0.71 | 0 | 0 | 0 | 0 | 0.76 | 2760 | 97 | 2170 | 1410 | 0.8 | 2760 | 98.5 | 1 | Enabled | |
0.86 | 0 | 0 | 0 | 0 | 0.9 | 2800 | 103.8 | 2220 | 1500 | 0.95 | 2840 | 106 | 1 | Enabled | |
1 | 0 | 0 | 0 | 0 | 1.05 | 2880 | 111.3 | 2220 | 1600 | 1.11 | 2920 | 115 | 1 | Enabled | |
1.15 | 0 | 0 | 0 | 0 | 1.19 | 2920 | 119.5 | 2210 | 1710 | 1.25 | 2960 | 123.3 | 1 | Enabled | |
1.29 | 0 | 0 | 0 | 0 | 1.34 | 3040 | 129.3 | 2220 | 1830 | 1.38 | 3040 | 131.6 | 1 | Enabled | |
1.43 | 0 | 0 | 0 | 0 | 1.48 | 3120 | 139.1 | 2240 | 1960 | 1.53 | 3120 | 143.6 | 1 | Enabled | |
1.57 | 0 | 0 | 0 | 0 | 1.62 | 3200 | 149.6 | 2260 | 2090 | 1.66 | 3240 | 151.1 | 1 | Enabled | |
1.71 | 0 | 0 | 0 | 0 | 1.76 | 3280 | 154.1 | 2320 | 2120 | 1.81 | 3280 | 155.6 | 0 | Enabled | |
1.86 | 0 | 0 | 0 | 0 | 1.9 | 3360 | 158.6 | 2370 | 2180 | 1.94 | 3400 | 159.4 | 0 | Enabled | |
1.99 | 0 | 0 | 0 | 0 | 2.05 | 3440 | 162.4 | 2410 | 2210 | 2.09 | 3480 | 163.2 | 0 | Enabled | |
2.13 | 0 | 0 | 0 | 0 | 2.17 | 3520 | 164.7 | 2390 | 2250 | 2.23 | 3560 | 166.9 | 0 | Enabled | |
2.28 | 0 | 0 | 0 | 0 | 2.33 | 3600 | 168.4 | 2450 | 2270 | 2.37 | 3640 | 169.9 | 0 | Enabled | |
2.42 | 0 | 0 | 0 | 0 | 2.46 | 3720 | 172.2 | 2470 | 2310 | 2.51 | 3720 | 173.7 | 0 | Enabled | |
2.56 | 0 | 0 | 0 | 0 | 2.61 | 3800 | 175.9 | 2500 | 2350 | 2.65 | 3800 | 176.7 | 0 | Enabled | |
2.7 | 0 | 0 | 0 | 0 | 2.74 | 3920 | 178.9 | 2510 | 2370 | 2.79 | 3920 | 180.5 | 0 | Enabled | |
2.84 | 0 | 0 | 0 | 0 | 2.88 | 3960 | 184.2 | 2540 | 2430 | 2.93 | 4000 | 185.7 | 0 | Enabled | |
2.98 | 0 | 0 | 0 | 0 | 3.02 | 4080 | 185.7 | 2540 | 2450 | 3.08 | 4120 | 186.5 | 0 | Enabled | |
3.12 | 0 | 0 | 0 | 0 | 3.17 | 4160 | 188.7 | 2540 | 2470 | 3.22 | 4200 | 188.7 | 0 | Enabled | |
3.26 | 0 | 0 | 0 | 0 | 3.31 | 4280 | 188.7 | 2540 | 2470 | 3.35 | 4280 | 188.7 | 0 | Enabled | |
3.4 | 0 | 0 | 0 | 0 | 3.44 | 4360 | 188.7 | 2540 | 2470 | 3.48 | 4400 | 188.7 | 0 | Enabled | |
3.52 | 0 | 0 | 0 | 0 | 3.57 | 4440 | 188.7 | 2550 | 2480 | 3.62 | 4480 | 188.7 | 0 | Enabled | |
3.67 | 0 | 0 | 0 | 0 | 3.71 | 4560 | 191 | 2540 | 2480 | 3.76 | 4600 | 191 | 0 | Enabled | |
3.81 | 0 | 0 | 0 | 0 | 3.85 | 4640 | 191.7 | 2540 | 2490 | 3.9 | 4680 | 191.7 | 0 | Enabled | |
3.94 | 0 | 0 | 0 | 0 | 4 | 4720 | 191.7 | 2540 | 2490 | 4.04 | 4760 | 191.7 | 0 | Enabled | |
4.09 | 0 | 0 | 0 | 0 | 4.13 | 4840 | 191.7 | 2540 | 2490 | 4.18 | 4840 | 191.7 | 0 | Enabled | |
4.23 | 0 | 0 | 0 | 0 | 4.27 | 4920 | 191.7 | 2540 | 2500 | 4.33 | 4960 | 191.7 | 0 | Enabled | |
4.37 | 0 | 0 | 0 | 0 | 4.41 | 5000 | 191.7 | 2530 | 2500 | 4.47 | 5000 | 191.7 | 0 | Enabled | |
4.51 | 0 | 0 | 0 | 0 | 4.56 | 5120 | 191.7 | 2520 | 2520 | 4.62 | 5120 | 191.7 | 0 | Enabled | |
4.67 | 0 | 0 | 0 | 0 | 4.71 | 5160 | 191.7 | 2510 | 2530 | 4.76 | 5240 | 191.7 | 0 | Enabled | |
4.81 | 0 | 0 | 0 | 0 | 4.85 | 5280 | 191.7 | 2500 | 2540 | 4.9 | 5320 | 191.7 | 0 | Enabled | |
4.94 | 0 | 0 | 0 | 0 | 4.99 | 5360 | 191.7 | 2490 | 2530 | 5.05 | 5400 | 191.7 | 0 | Enabled | |
5.09 | 0 | 0 | 0 | 0 | 5.14 | 5440 | 191.7 | 2480 | 2490 | 5.18 | 5440 | 191.7 | 0 | Enabled | |
5.23 | 0 | 0 | 0 | 0 | 5.27 | 5480 | 191.7 | 2480 | 2460 | 5.33 | 5520 | 191.7 | 0 | Enabled | |
5.37 | 0 | 0 | 0 | 0 | 5.42 | 5600 | 191.7 | 2470 | 2440 | 5.46 | 5640 | 191.7 | 0 | Enabled | |
5.52 | 0 | 0 | 0 | 0 | 5.55 | 5720 | 191.7 | 2450 | 2430 | 5.6 | 5720 | 191.7 | 0 | Enabled | |
5.65 | 0 | 0 | 0 | 0 | 5.7 | 5720 | 191.7 | 2440 | 2430 | 5.74 | 5800 | 191.7 | 0 | Enabled | |
5.8 | 0 | 0 | 0 | 0 | 5.84 | 5800 | 191.7 | 2430 | 2440 | 5.88 | 5840 | 191.7 | 0 | Enabled | |
5.94 | 0 | 0 | 0 | 0 | 5.99 | 5880 | 191.7 | 2420 | 2440 | 6.02 | 5920 | 191.7 | 0 | Enabled | |
6.07 | 0 | 0 | 0 | 0 | 6.12 | 5960 | 191.7 | 2410 | 2420 | 6.17 | 5960 | 191.7 | 0 | Enabled | |
6.21 | 0 | 0 | 0 | 0 | 6.26 | 6040 | 191.7 | 2410 | 2400 | 6.31 | 6080 | 191.7 | 0 | Enabled | |
6.36 | 0 | 0 | 0 | 0 | 6.4 | 6080 | 191.7 | 2400 | 2370 | 6.45 | 6120 | 191.7 | 0 | Enabled | |
6.49 | 0 | 0 | 0 | 0 | 6.55 | 6160 | 191.7 | 2390 | 2350 | 6.6 | 6200 | 191.7 | 0 | Enabled | |
6.66 | 0 | 0 | 0 | 0 | 6.7 | 6280 | 191.7 | 2390 | 2330 | 6.75 | 6320 | 191.7 | 0 | Enabled | |
6.79 | 0 | 0 | 0 | 0 | 6.83 | 6320 | 191.7 | 2380 | 2320 | 6.91 | 6360 | 191.7 | 0 | Enabled | |
6.96 | 0 | 0 | 0 | 0 | 7.01 | 6400 | 191.7 | 1790 | 2340 | 7.05 | 6400 | 185.7 | 0 | Enabled |
0.04 | 0 | 0 | 0 | 0 | 0.08 | 2320 | 83.5 | 2150 | 1290 | 0.13 | 2320 | 84.2 | 0 | Enabled | |
0.19 | 0 | 0 | 0 | 0 | 0.25 | 2360 | 86.5 | 2170 | 1330 | 0.29 | 2400 | 87.2 | 0 | Enabled | |
0.34 | 0 | 0 | 0 | 0 | 0.38 | 2440 | 88.7 | 2180 | 1370 | 0.44 | 2440 | 89.5 | 0 | Enabled | |
0.47 | 0 | 0 | 0 | 0 | 0.52 | 2480 | 91 | 2200 | 1400 | 0.57 | 2480 | 92.5 | 0 | Enabled | |
0.62 | 0 | 0 | 0 | 0 | 0.66 | 2520 | 93.2 | 2200 | 1430 | 0.71 | 2520 | 94.7 | 0 | Enabled | |
0.75 | 0 | 0 | 0 | 0 | 0.8 | 2560 | 97 | 2230 | 1470 | 0.85 | 2600 | 97.7 | 0 | Enabled | |
0.9 | 0 | 0 | 0 | 0 | 0.94 | 2640 | 100.8 | 2200 | 1510 | 0.99 | 2640 | 102.3 | 0 | Enabled | |
1.04 | 0 | 0 | 0 | 0 | 1.09 | 2680 | 105.3 | 2170 | 1550 | 1.13 | 2720 | 107.5 | 0 | Enabled | |
1.18 | 0 | 0 | 0 | 0 | 1.24 | 2760 | 111.3 | 2150 | 1610 | 1.29 | 2800 | 112.8 | 0 | Enabled | |
1.33 | 0 | 0 | 0 | 0 | 1.38 | 2840 | 117.3 | 2160 | 1690 | 1.44 | 2840 | 119.5 | 0 | Enabled | |
1.49 | 0 | 0 | 0 | 0 | 1.54 | 2920 | 124.1 | 2190 | 1770 | 1.58 | 2920 | 127.1 | 0 | Enabled | |
1.63 | 0 | 0 | 0 | 0 | 1.68 | 2960 | 132.3 | 2200 | 1870 | 1.73 | 3000 | 135.3 | 0 | Enabled | |
1.78 | 0 | 0 | -3 | 0 | 1.82 | 3040 | 141.4 | 2240 | 2000 | 1.86 | 3080 | 143.6 | 0 | Enabled | |
1.91 | 0 | 0 | -3 | 0 | 1.97 | 3160 | 148.9 | 2260 | 2070 | 2.02 | 3160 | 151.1 | 0 | Enabled | |
2.07 | 0 | 0 | -3 | 0 | 2.12 | 3240 | 152.6 | 2280 | 2100 | 2.16 | 3280 | 153.4 | 0 | Enabled | |
2.23 | 0 | 0 | -3 | 0 | 2.27 | 3320 | 155.6 | 2340 | 2140 | 2.32 | 3360 | 156.4 | 0 | Enabled | |
2.37 | 0 | 0 | -3 | 0 | 2.41 | 3400 | 159.4 | 2370 | 2190 | 2.46 | 3440 | 160.2 | 0 | Enabled | |
2.51 | 0 | 0 | -3 | 0 | 2.55 | 3520 | 160.9 | 2370 | 2220 | 2.6 | 3520 | 162.4 | 0 | Enabled | |
2.65 | 0 | 0 | -3 | 0 | 2.69 | 3560 | 165.4 | 2400 | 2230 | 2.74 | 3600 | 165.4 | 0 | Enabled | |
2.79 | 0 | 0 | -3 | 0 | 2.83 | 3680 | 166.2 | 2400 | 2230 | 2.88 | 3720 | 166.2 | 0 | Enabled | |
2.93 | 0 | 0 | -3 | 0 | 2.97 | 3760 | 168.4 | 2440 | 2270 | 3.03 | 3800 | 169.9 | 0 | Enabled | |
3.07 | 0 | 0 | -3 | 0 | 3.11 | 3840 | 171.4 | 2460 | 2290 | 3.16 | 3880 | 172.9 | 0 | Enabled | |
3.23 | 0 | 0 | -3 | 0 | 3.27 | 3920 | 175.2 | 2500 | 2330 | 3.32 | 3960 | 175.9 | 0 | Enabled | |
3.36 | 0 | 0 | -3 | 0 | 3.41 | 4040 | 179.7 | 2530 | 2380 | 3.46 | 4040 | 181.2 | 0 | Enabled | |
3.51 | 0 | 0 | -3 | 0 | 3.55 | 4120 | 182 | 2520 | 2400 | 3.59 | 4120 | 182 | 0 | Enabled | |
3.65 | 0 | 0 | -3 | 0 | 3.69 | 4200 | 183.5 | 2520 | 2430 | 3.74 | 4240 | 184.2 | 0 | Enabled | |
3.79 | 0 | 0 | -2.3 | 0 | 3.84 | 4320 | 183.5 | 2520 | 2430 | 3.88 | 4320 | 184.2 | 0 | Enabled | |
3.93 | 0 | 0 | -2.3 | 0 | 3.97 | 4400 | 184.2 | 2530 | 2450 | 4.02 | 4440 | 185 | 0 | Enabled | |
4.06 | 0 | 0 | -2.3 | 0 | 4.12 | 4520 | 185.7 | 2540 | 2460 | 4.16 | 4560 | 186.5 | 0 | Enabled | |
4.22 | 0 | 0 | -2.3 | 0 | 4.26 | 4600 | 187.2 | 2540 | 2460 | 4.3 | 4640 | 187.2 | 0 | Enabled | |
4.35 | 0 | 0 | -2.3 | 0 | 4.4 | 4720 | 188 | 2540 | 2450 | 4.45 | 4720 | 188.7 | 0 | Enabled | |
4.49 | 0 | 0 | 0 | 0 | 4.54 | 4800 | 190.2 | 2540 | 2490 | 4.59 | 4840 | 191 | 0 | Enabled | |
4.63 | 0 | 0 | 0 | 0 | 4.68 | 4880 | 191.7 | 2540 | 2470 | 4.72 | 4920 | 191.7 | 0 | Enabled | |
4.77 | 0 | 0 | 0 | 0 | 4.82 | 4960 | 191.7 | 2540 | 2500 | 4.87 | 5000 | 191.7 | 0 | Enabled | |
4.91 | 0 | 0 | 0 | 0 | 4.96 | 5080 | 191.7 | 2530 | 2510 | 5.01 | 5120 | 191.7 | 0 | Enabled | |
5.05 | 0 | 0 | 0 | 0 | 5.1 | 5120 | 191.7 | 2520 | 2510 | 5.15 | 5160 | 191.7 | 0 | Enabled | |
5.2 | 0 | 0 | 0 | 0 | 5.24 | 5200 | 191.7 | 2510 | 2510 | 5.29 | 5240 | 191.7 | 0 | Enabled | |
5.33 | 0 | 0 | 0 | 0 | 5.38 | 5320 | 191.7 | 2500 | 2510 | 5.43 | 5360 | 191.7 | 0 | Enabled | |
5.47 | 0 | 0 | 0 | 0 | 5.52 | 5440 | 191.7 | 2490 | 2510 | 5.57 | 5440 | 191.7 | 0 | Enabled | |
5.62 | 0 | 0 | 0 | 0 | 5.66 | 5480 | 191.7 | 2480 | 2490 | 5.71 | 5480 | 191.7 | 0 | Enabled | |
5.75 | 0 | 0 | 0 | 0 | 5.81 | 5560 | 191.7 | 2470 | 2480 | 5.85 | 5560 | 191.7 | 0 | Enabled | |
5.89 | 0 | 0 | 0 | 0 | 5.95 | 5640 | 191.7 | 2460 | 2460 | 6.01 | 5680 | 191.7 | 0 | Enabled | |
6.06 | 0 | 0 | 0 | 0 | 6.1 | 5760 | 191.7 | 2440 | 2410 | 6.14 | 5760 | 191.7 | 0 | Enabled | |
6.2 | 0 | 0 | 0 | 0 | 6.25 | 5800 | 191.7 | 2440 | 2410 | 6.31 | 5840 | 191.7 | 0 | Enabled | |
6.35 | 0 | 0 | 0 | 0 | 6.4 | 5880 | 191.7 | 2430 | 2400 | 6.45 | 5920 | 191.7 | 0 | Enabled | |
6.49 | 0 | 0 | 0 | 0 | 6.54 | 5960 | 191.7 | 2420 | 2400 | 6.59 | 5960 | 191.7 | 0 | Enabled | |
6.63 | 0 | 0 | 0 | 0 | 6.68 | 6080 | 191.7 | 2410 | 2390 | 6.72 | 6080 | 191.7 | 0 | Enabled | |
6.78 | 0 | 0 | 0 | 0 | 6.82 | 6120 | 191.7 | 2400 | 2390 | 6.86 | 6160 | 191.7 | 0 | Enabled | |
6.91 | 0 | 0 | 0 | 0 | 6.96 | 6240 | 191.7 | 2400 | 2370 | 7.01 | 6240 | 191.7 | 0 | Enabled | |
7.05 | 0 | 0 | 0 | 0 | 7.1 | 6240 | 191.7 | 2400 | 2360 | 7.16 | 6280 | 191.7 | 0 | Enabled | |
7.22 | 0 | 0 | 0 | 0 | 7.28 | 6360 | 191.7 | 2390 | 2350 | 7.32 | 6360 | 191.7 | 0 | Enabled | |
7.36 | 0 | 0 | 0 | 0 | 7.41 | 6400 | 191.7 | 2380 | 2360 | 7.46 | 6400 | 191.7 | 0 | Enabled | |
7.51 | 0 | 0 | 0 | 0 | 7.56 | 6520 | 191.7 | 2380 | 2350 | 7.6 | 6560 | 191.7 | 0 | Enabled | |
7.65 | 0 | 0 | 0 | 0 | 7.69 | 6600 | 191.7 | 2370 | 2330 | 7.73 | 6560 | 191.7 | 0 | Enabled | |
7.79 | 0 | 0 | 0 | 0 | 7.83 | 6600 | 175.2 | 1450 | 2400 | 7.89 | 6600 | 162.4 | 0 | Enabled | |
7.95 | 0 | 0 | 0 | 0 | 7.99 | 6560 | 67.7 | 850 | 2500 | 8.04 | 6520 | 46.6 | 0 | Enabled |
0.05 | 0 | 0 | 0 | 0 | 0.09 | 2200 | 85 | 2160 | 1310 | 0.13 | 2240 | 85 | 0 | Enabled | |
0.19 | 0 | 0 | 0 | 0 | 0.25 | 2280 | 86.5 | 2160 | 1340 | 0.29 | 2280 | 87.2 | 0 | Enabled | |
0.33 | 0 | 0 | 0 | 0 | 0.39 | 2320 | 88 | 2180 | 1360 | 0.43 | 2320 | 88.7 | 0 | Enabled | |
0.48 | 0 | 0 | 0 | 0 | 0.52 | 2360 | 90.2 | 2210 | 1390 | 0.58 | 2360 | 91 | 0 | Enabled | |
0.62 | 0 | 0 | 0 | 0 | 0.66 | 2400 | 91.7 | 2240 | 1410 | 0.71 | 2440 | 92.5 | 0 | Enabled | |
0.76 | 0 | 0 | 0 | 0 | 0.8 | 2440 | 94 | 2220 | 1440 | 0.85 | 2440 | 94.7 | 0 | Enabled | |
0.89 | 0 | 0 | 0 | 0 | 0.95 | 2520 | 96.2 | 2260 | 1470 | 0.99 | 2520 | 97 | 0 | Enabled | |
1.04 | 0 | 0 | 0 | 0 | 1.09 | 2560 | 98.5 | 2280 | 1500 | 1.13 | 2560 | 99.2 | 0 | Enabled | |
1.18 | 0 | 0 | 0 | 0 | 1.24 | 2600 | 102.3 | 2240 | 1540 | 1.29 | 2640 | 103.8 | 0 | Enabled | |
1.33 | 0 | 0 | 0 | 0 | 1.38 | 2680 | 106.8 | 2210 | 1570 | 1.43 | 2720 | 107.5 | 0 | Enabled | |
1.48 | 0 | 0 | 0 | 0 | 1.53 | 2760 | 111.3 | 2190 | 1620 | 1.58 | 2760 | 112.8 | 0 | Enabled | |
1.63 | 0 | 0 | 0 | 0 | 1.68 | 2800 | 117.3 | 2170 | 1690 | 1.73 | 2840 | 119.5 | 0 | Enabled | |
1.78 | 0 | 0 | 0 | 0 | 1.82 | 2880 | 123.3 | 2180 | 1770 | 1.86 | 2920 | 125.6 | 0 | Enabled | |
1.92 | 0 | 0 | 0 | 0 | 1.96 | 2960 | 130.1 | 2230 | 1850 | 2.01 | 2960 | 133.1 | 0 | Enabled | |
2.05 | 0 | 0 | 0 | 0 | 2.1 | 3040 | 138.3 | 2240 | 1970 | 2.14 | 3040 | 140.6 | 0 | Enabled | |
2.2 | 0 | 0 | 0 | 0 | 2.24 | 3120 | 146.6 | 2280 | 2070 | 2.29 | 3160 | 148.1 | 0 | Enabled | |
2.34 | 0 | 0 | 0 | 0 | 2.38 | 3200 | 149.6 | 2270 | 2080 | 2.43 | 3200 | 150.4 | 0 | Enabled | |
2.48 | 0 | 0 | 0 | 0 | 2.54 | 3280 | 152.6 | 2320 | 2120 | 2.59 | 3320 | 153.4 | 0 | Enabled | |
2.63 | 0 | 0 | 0 | 0 | 2.68 | 3360 | 154.1 | 2320 | 2130 | 2.73 | 3400 | 154.9 | 0 | Enabled | |
2.78 | 0 | 0 | 0 | 0 | 2.82 | 3480 | 156.4 | 2330 | 2170 | 2.87 | 3480 | 157.9 | 0 | Enabled | |
2.92 | 0 | 0 | 0 | 0 | 2.96 | 3560 | 158.6 | 2350 | 2180 | 3.01 | 3560 | 160.2 | 0 | Enabled | |
3.06 | 0 | 0 | 0 | 0 | 3.1 | 3640 | 161.7 | 2360 | 2220 | 3.15 | 3680 | 163.2 | 0 | Enabled | |
3.2 | 0 | 0 | 0 | 0 | 3.25 | 3720 | 165.4 | 2410 | 2230 | 3.29 | 3760 | 165.4 | 0 | Enabled | |
3.34 | 0 | 0 | 0 | 0 | 3.39 | 3800 | 166.9 | 2410 | 2260 | 3.43 | 3840 | 167.7 | 0 | Enabled | |
3.49 | 0 | 0 | 0 | 0 | 3.54 | 3920 | 169.9 | 2420 | 2280 | 3.59 | 3920 | 170.7 | 0 | Enabled | |
3.64 | 0 | 0 | 0 | 0 | 3.69 | 4000 | 172.9 | 2460 | 2300 | 3.73 | 4040 | 173.7 | 0 | Enabled | |
3.77 | 0 | 0 | 0 | 0 | 3.83 | 4040 | 175.9 | 2490 | 2320 | 3.87 | 4120 | 175.9 | 0 | Enabled | |
3.92 | 0 | 0 | 0 | 0 | 3.96 | 4160 | 175.9 | 2500 | 2350 | 4.01 | 4200 | 176.7 | 0 | Enabled | |
4.05 | 0 | 0 | 0 | 0 | 4.1 | 4280 | 178.9 | 2530 | 2390 | 4.15 | 4280 | 180.5 | 0 | Enabled | |
4.2 | 0 | 0 | 0 | 0 | 4.25 | 4360 | 182 | 2500 | 2420 | 4.31 | 4440 | 182 | 0 | Enabled | |
4.35 | 0 | 0 | 0 | 0 | 4.4 | 4440 | 182.7 | 2530 | 2410 | 4.44 | 4480 | 182.7 | 0 | Enabled | |
4.49 | 0 | 0 | 0 | 0 | 4.54 | 4560 | 185 | 2540 | 2430 | 4.59 | 4600 | 185.7 | 0 | Enabled | |
4.63 | 0 | 0 | 0 | 0 | 4.68 | 4680 | 186.5 | 2540 | 2470 | 4.73 | 4680 | 187.2 | 0 | Enabled | |
4.77 | 0 | 0 | 0 | 0 | 4.82 | 4720 | 188.7 | 2540 | 2450 | 4.86 | 4760 | 188.7 | 0 | Enabled | |
4.92 | 0 | 0 | 0 | 0 | 4.96 | 4840 | 189.5 | 2540 | 2460 | 5.01 | 4880 | 189.5 | 0 | Enabled | |
5.06 | 0 | 0 | 0 | 0 | 5.1 | 4920 | 191 | 2540 | 2480 | 5.15 | 4920 | 191.7 | 0 | Enabled | |
5.19 | 0 | 0 | 0 | 0 | 5.26 | 5000 | 191.7 | 2540 | 2480 | 5.3 | 5040 | 191.7 | 0 | Enabled | |
5.36 | 0 | 0 | 0 | 0 | 5.4 | 5120 | 191.7 | 2530 | 2500 | 5.45 | 5160 | 191.7 | 0 | Enabled | |
5.49 | 0 | 0 | 0 | 0 | 5.54 | 5200 | 191.7 | 2520 | 2500 | 5.59 | 5240 | 191.7 | 0 | Enabled | |
5.63 | 0 | 0 | 0 | 0 | 5.68 | 5280 | 191.7 | 2520 | 2500 | 5.73 | 5320 | 191.7 | 0 | Enabled | |
5.78 | 0 | 0 | 0 | 0 | 5.82 | 5320 | 191.7 | 2510 | 2500 | 5.87 | 5360 | 191.7 | 0 | Enabled | |
5.92 | 0 | 0 | 0 | 0 | 5.96 | 5400 | 191.7 | 2500 | 2490 | 6.01 | 5440 | 191.7 | 0 | Enabled | |
6.05 | 0 | 0 | 0 | 0 | 6.11 | 5520 | 191.7 | 2480 | 2450 | 6.15 | 5520 | 191.7 | 0 | Enabled | |
6.19 | 0 | 0 | 0 | 0 | 6.25 | 5600 | 191.7 | 2480 | 2470 | 6.29 | 5600 | 191.7 | 0 | Enabled | |
6.34 | 0 | 0 | 0 | 0 | 6.39 | 5680 | 191.7 | 2470 | 2460 | 6.43 | 5680 | 191.7 | 0 | Enabled | |
6.48 | 0 | 0 | 0 | 0 | 6.53 | 5760 | 191.7 | 2460 | 2460 | 6.58 | 5760 | 191.7 | 0 | Enabled | |
6.62 | 0 | 0 | 0 | 0 | 6.67 | 5840 | 191.7 | 2440 | 2450 | 6.72 | 5880 | 191.7 | 0 | Enabled | |
6.76 | 0 | 0 | 0 | 0 | 6.81 | 5880 | 191.7 | 2440 | 2440 | 6.86 | 5920 | 191.7 | 0 | Enabled | |
6.91 | 0 | 0 | 0 | 0 | 6.95 | 6040 | 191.7 | 2420 | 2420 | 7 | 6040 | 191.7 | 0 | Enabled | |
7.05 | 0 | 0 | 0 | 0 | 7.1 | 6040 | 191.7 | 2420 | 2400 | 7.15 | 6040 | 191.7 | 0 | Enabled |
Drum roll..... How did she run? Better or worse... are we going in right direction?
How does the plug in cyl 3 look. (check gap and plug color again)
