Whitedemon
- Miami, FL
Hey guys, I need some help here, my car is 08 GTI TFSI, recently I've been adding some mods to it but the main one being a water/meth kit. I have a Borg Warner K04 installed with Revo stage 3 software (have had it for almost 4 years now), my car would usually boost at peak 25-26 psi and hold around 23 psi, but ever since I installed the WMI and changed the settings using the SPS switch (upped the timing from 4 to 7) my car hasn't been boosting as before. Now, I don't know if it's just a coincidence that this happens at the same time I installed WMI, I also replaced the oem throttle body pipe with the CTS turbo one and replaced the intercooler hoses. I've checked every boost pipe/hose, make sure all the clamps are tighten up, visually at least I haven't been able to find any boost leak.
Other things I've done trying to fix the issue:
. Deleted PCV valve (replaced with oil catch can)
. Replaced DV valve with GFB DV +
. Checked for fault codes using VAGCOM - nothing comes up
I did some logging (requested vs actual boost) with the settings at B8 T7 F9
Once I reverted the settings back to stock, this is what I got
You can see how when the ECU is in stock actual matches up with specified easily and even passes it. So could it be the ECU map?
Any other ideas of what it could be???
I appreciate any help you guys could provide me, this issue has been driving me insane for quite some time now. Thanks.
