posted below my friend has a 07 GTI 2 door and stuck with a few issues we've change spark plugs and coilpacks and now awaiting a carbon cleaning adapter to be delivered any help is greatly appreciated. i also have videos available as well
Code:
Wednesday,13,May,2020,19:12:49:30972
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWFV71K47W108004 License Plate: JOSH
Mileage: 267240km-166055mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFV71K47W108004 Mileage: 267240km-166055miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH15--- Serial number: VWZ7Z0F8184533
Coding: 0403010A1C070160
Shop #: WSC 08057 444 92481
VCID: 2B03FA4EFF02BF93D69-807E
6 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 267165 km
Time Indication: 0
Date: 2000.00.00
Time: 19:07:23
Freeze Frame:
RPM: 2210 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 42.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.605 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 267165 km
Time Indication: 0
Date: 2000.00.00
Time: 19:07:23
Freeze Frame:
RPM: 2210 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 42.0°C
Voltage: 14.605 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 267165 km
Time Indication: 0
Date: 2000.00.00
Time: 19:07:29
Freeze Frame:
RPM: 2248 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 42.0°C
Voltage: 14.605 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 267165 km
Time Indication: 0
Date: 2000.00.00
Time: 19:14:29
Freeze Frame:
RPM: 875 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 47.0°C
Voltage: 14.478 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 267246 km
Time Indication: 0
Date: 2000.00.00
Time: 20:15:48
Freeze Frame:
RPM: 519 /min
Load: 43.5 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 46.0°C
Voltage: 12.065 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 267246 km
Time Indication: 0
Date: 2000.00.00
Time: 22:27:49
Freeze Frame:
RPM: 1351 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 39.0°C
Voltage: 14.478 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 070 1306
Revision: 04507000 Serial number: 00000610030470
Coding: 0000020
Shop #: WSC 01279 785 00200
VCID: 221D176A88C87EDB65F-8076
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B3222E67B2A7535E9-8026
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
00474 - Control Module for Immobilizer
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70B92D2216A49C4BA3B-8024
1 Fault Found:
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000006279375
Coding: 178D8F214004150000140000001400000028770B5C0000
Shop #: WSC 08091 444 59108
VCID: 372BD63E334A0B73A21-8062
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 211006 020 0501
Coding: 00038805
Shop #: WSC 08091
4 Faults Found:
00532 - Supply Voltage B+
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 267109 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 15.50 V
OFF
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 7
Reset counter: 189
Mileage: 267109 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.50 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 189
Mileage: 267109 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.55 V
ON
ON
OFF
OFF
OFF
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 189
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
ON
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0003562
VCID: 2E05F35ACC10CABBF17-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 148
Mileage: 267109 km
Time Indication: 0
Date: 2000.00.00
Time: 13:34:19
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 5L AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0754Y/
Coding: 0013644
Shop #: WSC 01269 785 00200
VCID: 6C8139523A8C78AB9F3-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME133733652
Subsystem 3 - Serial number: 6342MSME143D41323
Subsystem 4 - Serial number: 6352QSME193B401DJ
Subsystem 5 - Serial number: 6362QSME176D1227H
Subsystem 6 - Serial number: 63727SME0A3E5937B
Subsystem 7 - Serial number: 63827SME0B251547$
2 Faults Found:
00591 - Seat Belt Switch; Driver (E24)
010 - Open or Short to Plus - Intermittent - MIL ON
004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 036 0070
Coding: 0012122
VCID: 77AB163E73CACB73621-8022
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8184533
Coding: 0007207
Shop #: WSC 08057 444 999999
VCID: 313FE826DD2ED543EC5-8064
11 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 189
Mileage: 0 km
Time Indication: 0
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 189
Mileage: 0 km
Time Indication: 0
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 189
Mileage: 0 km
Time Indication: 0
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 189
Mileage: 0 km
Time Indication: 0
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 189
Mileage: 0 km
Time Indication: 0
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 189
Mileage: 0 km
Time Indication: 0
00457 - Central Electronics Control Module / BCM (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 189
Mileage: 0 km
Time Indication: 0
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 189
Mileage: 0 km
Time Indication: 0
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 6
Reset counter: 189
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 0 km
Time Indication: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 0 km
Time Indication: 0
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 22080602001211
Coding: 7F8F03600F000000
VCID: 2F3BEE5ECB1AC3B3FA1-807A
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 189
Time Indication: 0
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Time Indication: 0
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T1MNJ03
VCID: 7DA7041651F6E12338D-8028
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 0 km
Time Indication: 0
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Shop #: WSC 62132 000 1048576
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 189
Time Indication: 0
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 267246 km
Time Indication: 0
Date: 2000.00.00
Time: 20:15:48
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0967
Coding: 0001077
VCID: 3829D5023E54040BABB-806C
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 3431E132223CE06B873-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
VCID: 045171F2321C90EB773-8050
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 392FD006055E1D03545-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1213262BCA06B473-8020
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 017 0035
Revision: 00017000 Serial number: VWZ5Z7F2114038
Coding: 0040401
VCID: 2411117292DC70EB173-8070
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0440
Coding: 0100101
1 Fault Found:
00667 - Ambient Temperature Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 189
Mileage: 0 km
Time Indication: 0
End----------(Elapsed Time: 01:17, VBatt start/end: 12.2V/12.2V)-----------
