Perpetuus' MkV Build Thread
Perpetuus
Data Encryption
In my garage
Nice clean build man. Think you'll stop after your incoming list is completed?
Thanks! Probably not just yet. I also have a K04 and a bunch of parts not on the list ;)
freshpots
r'zub n t'zug
Toronto, CAN
2007 GTI
You should add a new air compressor hose fitting, that thing leaked more than my piece of shit GTI did
Tapatalkin
Perpetuus
Data Encryption
In my garage
AWE downpipe installed (10/18/2013). Sounds amazing and the extra power is very noticeable but quite loud with my engine mounts!
Perpetuus
Data Encryption
In my garage
And new pic for clicks ;)
Perpetuus
Data Encryption
In my garage
Something arrived...
Perpetuus
Data Encryption
In my garage
Initially wanted to clean my intake valves and put everything back to normal, but don't want to remove that intake manifold again anytime soon...
Intake Manifold fully removed out of the car. 3 out of 4 injectors came out with the manifold!
Rebuilding my K04 and putting it in while the car is down....hopefully completed sometime next month.
Busted K04
Perpetuus
Data Encryption
In my garage
Also picked up these bad boys today:
Perpetuus
Data Encryption
In my garage
Valve cleaning finished last month, at 34,XXX miles.
Before...
After...
K04 being installed. Drained all the coolant out today:
Perpetuus
Data Encryption
In my garage
K04 being cleaned
Took the compressor housing off to clean the K04 before installing it
Perpetuus
Data Encryption
In my garage
K04 is installed!
Time to hook everything back up.
Perpetuus
Data Encryption
In my garage
Topped up with Redline 5W40 oil today
Mixed some coolant
Routed vacuum hose to DV
Perpetuus
Data Encryption
In my garage
Ran the car a little today while I refilled the coolant.
The idling is much smoother after the valve cleaner, but the car would stall on hard throttle. I assume the S3 injectors run too rich. Still waiting for tune... this week.
Also cleaned the VWR filter today.
Perpetuus
Data Encryption
In my garage
Some missing photos from my phone:
AWE DV, good for 650hp
S3 Injectors, assembled and ready to install
Noise Maker Device under the rain tray, removed.
Intake Manifold Support that I cut in half to free the intake manifold. The original triple square bolt (left) stripped. I replaced it with a 13mm hex bolt and it works great. Better access too.
