worldacgti
Anyone run into this code? Checked hoses and wiring and everything seems to be intact. I clear it and it pops right up again...
Sent from my SM-G965W using Tapatalk
thank you sir
Code is back for me as of this past weekend.
Thankfully, it stayed away long enough to get the car inspected.
I can hear the pump (i think that's what it is) on cold start. I park in my garage at home, so it's pretty evident when it opens then closes. Opens a few seconds after startup and runs for 5-10 seconds then stops.
More investigating needed, i guess. New (used) pump was put in last month.
Odd that the OP and I have very similar mods (autotech intake, uni IC, CTS TIP, moosetuned is38, and meth) I wonder if one or a combination of them is causing the fault.
Which code? Pretty sure there's a valve that opens and closes when SAI pump kicks on that is controlled by ECU. The valve might be bad instead of the pump. Also, pretty sure it's supposed to run for more than 5-10 seconds.
Where exactly is the combi valve located? Pics?I'll pull the code again after my trip home from work.
I think it was the 0413 again, but i'll look.
I misworded above, i replaced the valve last month, not the pump. Combi valve, PN 06K131097K
I'm just assuming it's sai noise, as it sounds much like intake noise, but louder, kinda like putting your ear closer to an open element intake at idle. Definitely intake noise of some sort.
Edit: yup 0413 it's back again.
