arj116
- toronto, canada
- 08 GTI DSG
Hello,
first off yes i did use the search function...half the threads don't half solutions because OP's don't report back or the go off topic on whos schwartz is bigger....
long story short...went for a drive last night outside temp was -10C
decided to do WOT 4th gear....i hit redline and and the car bogged and that was that....No boost pressure was being built and the car was severely down on power....got it home scanned it with vcds...got a MAF code and the p0087...i cleared it and went for trip around the block...if i got wot the car goes no where....my afr gauge shows that fuel is being dumped because at 2nd gear struggling to even hit 3k my afr shows 11.4 :1
light came back on again and this time it was p0087
here is the freeze frame
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69245 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:54
Freeze Frame:
RPM: 827 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 11.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.605 V
P0087 - 008 - Too Low
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69245 km
Time Indication: 0
Date: 2000.00.00
Time: 12:23:00
Freeze Frame:
RPM: 1477 /min
Load: 25.5 %
Speed: 19.0 km/h
Temperature: 81.0°C
Temperature: 9.0°C
Voltage: 14.351 V
i logged rail pressure spec vs actual here is the disaster of a result
Uploaded with ImageShack.us
any help i would appreciate
mods are in sig...i dont have a cam folower i did the h2sportfix and i had bought a brand new apr hpfp.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69245 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:54
Freeze Frame:
RPM: 827 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 11.0°C
Voltage: 14.605 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69245 km
Time Indication: 0
Date: 2000.00.00
Time: 12:23:00
Freeze Frame:
RPM: 1477 /min
Load: 25.5 %
Speed: 19.0 km/h
Temperature: 81.0°C
Temperature: 9.0°C
Voltage: 14.351 V
