Got the turbo installed and finished today. No exhaust smoke. It still has a foul odor, but hoping it is from the residual oil in the intercoolers. I didn't swap my Forge WG actuator from the old K04 onto the new and it only boosts to 20 psi, when it was easily making 24 psi with little preload with the Forge. So first, I am going to do a bit of necessary hose trimming (just some nagging fitment issues I never dealt with) and replace all hose clamps. Then see what the data is showing for specified and actual boost. Then, if needed, I will add a bit of preload to the factory WG actuator and hope it can then make target boost. Before installing it, I checked the preload and there were four turns of the WGA rod's adjusting nut. Will not be pleased if I need to swap the new WG actuator for the Forge for the factory WGA having a weak spring.
