trialerror00
- Southern Maryland
- k04 GTI & watermeth
Good evening. I replaced my oil pump and oil pressure sensor today (due to low oil pressure) and now I have all cylinders misfiring. I have a 2009 GTI with the 2.0TSI (engine CCTA), the timing chain and tensioner were all replaced 12k miles ago and I recently replaced the clutch, 15 miles ago. I understand that the oil pump is not required to be timed, so correct me if I'm wrong. Any and all help is greatly appreciated.
Here is the scan from this afternoon
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H83NN8EG
Coding: 0403010A18070160
Shop #: WSC 64849 512 16512
VCID: 69D9400E40E60FC374-803C
6 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:38
Freeze Frame:
RPM: 746 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 31.0°C
Voltage: 14.097 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 000 - Incorrect Correlation
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:54:13
Freeze Frame:
RPM: 978 /min
Load: 28.6 %
Speed: 3.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.970 V
Readiness: 0110 0100
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:33
Freeze Frame:
RPM: 832 /min
Load: 32.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.843 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:38
Freeze Frame:
RPM: 746 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 31.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181652 km
Time Indication: 0
Date: 2000.00.00
Time: 23:54:13
Freeze Frame:
RPM: 978 /min
Load: 28.6 %
Speed: 3.0 km/h
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 13.970 V
