2010-2014 Volkswagen GTI Mk6 Bi-Xenon Headlamp Assembly
These are the original lights that came on my non-accident vehicle. I ended up replacing the lenses with aftermarket lenses and had to do a little work to make them fit, but they are clear!
5K0941751B qty (1)
5K0941752B qty (1)
PN Supersession: 5K0941753B (confirmed compatible)
PN Supersession: 5K0941754B (confirmed compatible)
Note: These are headlamp assemblies, you will still need to utilize your old ballasts / modules and bulbs. I professionally replaced the lenses on these as well, so they are clear. Brand new oem set is approx $1500, so $850 for both is a steal.
I'm not sure if these are plug and play if your vehicle came with stock halogens, but they are plug and play if your vehicle came stock with BiXenons. Just make sure you have the ballasts / modules and bulbs.
Bulb Igniter 5M0-907-391
Leveling Module 7L6-941-329-B
Xenon Headlight Bulb N-105-661-03 (or D1S Bulb).
I'm located in 90042, and can meet you around there.
5K0941751B qty (1)
5K0941752B qty (1)
