g60_corrado_91
- IL
- 2006 GTI 6MT Pkg 1
Maybe I'm jumping the gun, but I just got a thing in the mail from XM saying they'd be giving me two weeks free of XM radio starting February 1st. I've had XM in the past and cancelled it about a year ago. When I scan my car with my Vag Com, I get the warning that says my tuner is not enabled/activated under the 0F-Digital Radio module.
I decided to hit the SAT button to see if it still worked, even though it hasn't been activated yet. That's when I discovered the "NO SIGNL" message, even under the preview channel. I was under the impression that it'd still pick the preview channel up even not being a current subscriber.
So, my question is, do I have a faulty satellite antenna? I don't get the 02633 error which is a short in the antenna itself.
The only error I get is this, which I believe is just a message telling you that you're not a current subscriber.
Saturday,28,January,2012,13:54:36:46054
VCDS Version: Release 11.11.2 (x64)
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Control Module Part Number: 8E0 035 593 E HW: 8E0 035 593 E
Component and/or Version: SDAR XM H03 0080
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 2B5EB7D08A1E11B
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 226
Mileage: 163162 km
Time Indication: 0
Date: 2000.00.00
Time: 13:28:41
I will know on February 1st for sure if it'll pick up the channels, but I'm hoping XM/Sirius just changed the policy to not be able to pick anything up until you're a subscriber.
Any thoughts?
This is the short code, but this is from this thread, not from my car:
http://forums.fourtitude.com/showthread.php?4508301
02633 - Antenna for Satellite Tuner
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 202
Time Indication: 0
Here's the satellite antenna short, that I'm not getting.
Software Coding:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 226
Mileage: 163162 km
Time Indication: 0
Date: 2000.00.00
Time: 13:28:41
Any thoughts?
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 202
Time Indication: 0
