New Headlights Not Working
usetheBFH
Pittsburgh, PA
Bought a new set of headlights for my 2007 MKV GTI and they arent working at all. Ran VCDS, see below. Something i need to change in the coding? Any thoughts on where to start here? My fog lights work fine.
Friday,11,September,2020,07:47:10:24961
VCDS Version: Release 19.6.2 (x64) Running on Windows 8 x64
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 AE HW: 3C0 937 049 AE
Component and/or Version: Bordnetz-SG H52 2002
Software Coding: 178D0F214004150047140000001400000039770B5C0001
Work Shop Code: WSC 03751 444 54648
Additional Info: 1K1955119E Wischer 030507 021 0501
VCID: 6CF1F77B4FEA762F69-8038
10 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 185
Mileage: 353033 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.40 V
ON
ON
OFF
OFF
ON
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 185
Mileage: 353033 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.45 V
ON
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 185
Mileage: 332629 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 146
Reset counter: 185
Mileage: 332629 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
02498 - Left Low Beam Reflector Motor (V294)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 353034 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
02499 - Right Low Beam Reflector Motor (V295)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 353034 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 353033 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.25 V
ON
ON
OFF
OFF
ON
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 353033 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
ON
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 185
Mileage: 353033 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 185
Mileage: 353033 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
OFF
GTI's
MD
So your original HID functioned completely before you installed the new replacement HID?? Did you confirm they are plugged in completely and that the Fuses are Ok.
