Weixb
- Boston, MA, USA
- 2006 GTI
Hello all!
I am struggling with finding a solution to P2187- System lean at idle.
Attached is a VCDS scan from about an hour ago.
This is my first time working on a car, so I’m still trying to learn some of the terminology; my advance apologies for poor descriptions, or if I’m not providing enough information!
The car has been running great; no noticeable decrease in performance except for perhaps reduced gas mileage. The P2187 code started popping up a few weeks ago, and after clearing the code several times, it has started popping up more frequently.
The only noticeable issue has been that the car will take slightly longer to turn over if it has been sitting for a while- maybe a second and a half, rather than almost instantaneously, as it does when it’s been recently shut off.
So far, I’ve noticed or checked the following:
Car idles fine; revs don’t increase or decrease at all at idle.
Slight hissing coming from the PCV valve area, but it’s relatively quiet. Engine idles fine with oil cap/dip stick in place, but if either are removed, the engine idles rough.
I did damage a clip on one of the hoses coming out of the PCV valve when I was trying to maneuver to the banjo bolt on the HPFP (the hose on the far right that ducks down underneath the brake booster hosing/coolant lines)- but it looks like it’s holding in place well, and hasn’t moved at all since I stuck it back on
N80 valve was replaced by a Bosch part about a month ago
Brake booster hoses look newer- I didn’t see or feel any visible cracks; no unexpected noises from that part of the engine at idle.
Cleaned MAF sensor connector, didn’t change anything
Nothing looks substantially out of the ordinary in blocks 32 or 33- if additional info is needed, let me know
Block 002 registering around 2 at idle
Block 30 might be interesting- B1S1 is constantly stuck at the same value, while B1S2 fluctuates.
Block 36 in basic settings says B1S1 OK, with a value of 1.36
Block 046 in basic settings says CAT B1 OK
Any advice on how to proceed would be greatly appreciated! Thanks for your help!
