jacques1397
Hi from South Africa,
I have a quick question for you all running K04. Some background, I own a UG MkV K04 with bigger cooler, cold air induction, S3 Injectors etc. Motor was recently rebuilt, due to numerous small problems, so I know its 100% sound.
I had time to log my fueling, boost and AFR.
I noticed for once, no boost leaks, AFR seems on point, little rich/lean, not 100% sure to work that out, but none the less, the LPFP seems to be dropping pressure on higher RPM. Any idea why this will happen? Normal? That's my only conclusion to why she is not as healthy as its supposed to be. I also seems to be having a dirty throttle body, or its faulty, doesn't seem to open to 99.6% as far as I know it should?
Logs below.
Thanks
Logs below.
Marker | Group 1 - Field 0 | Group 5 - Field 1 | Group 14 - Field 2 | Group 31 - Field 0 | Group 31 - Field 1 | Group 62 - Field 0 | Group 62 - Field 1 | Group 103 - Field 0 | Group 106 - Field 0 | Group 115 - Field 2 | Group 117 - Field 3 | Group 230 - Field 0 |
Engine Speed - (G28) | Engine Load | Misfire Counter | Lambda Control - Bank 1 (actual) | Lambda Control - Bank 1 (specified) | Throttle Valve - Sensor 1 (G187) | Throttle Valve - Sensor 2 (G188) | Current - Fuel Pressure | Fuel Rail - Pressure (actual) | Boost Pressure - (specified) | Boost Pressure - (specified) | Rail Pressure - (specified) | |
/min | % | % | % | bar | bar | mbar | mbar | bar | ||||
1 | 2560 | 46.6 | 0 | 0.95 | 1 | 35.9 | 60.5 | 3.98 | 91.77 | 730 | 730 | 93.15 |
2720 | 120.3 | 0 | 0.93 | 0.94 | 88.3 | 7.8 | 3.99 | 115.39 | 2280 | 2480 | 120.75 | |
3120 | 191.7 | 0 | 0.95 | 0.94 | 87.9 | 8.2 | 4.6 | 124.45 | 2550 | 2550 | 128.98 | |
3640 | 191.7 | 0 | 0.78 | 0.8 | 88.3 | 7.8 | 3.96 | 125.48 | 2540 | 2540 | 128.99 | |
4120 | 191.7 | 0 | 0.78 | 0.79 | 88.3 | 8.2 | 3.6 | 124.07 | 2540 | 2540 | 128.99 | |
4640 | 191.7 | 0 | 0.76 | 0.77 | 87.9 | 8.2 | 3.04 | 126.35 | 2540 | 2540 | 128.99 | |
5080 | 191.7 | 0 | 0.76 | 0.78 | 86.3 | 10.2 | 2.68 | 125.1 | 2540 | 2540 | 128.99 | |
5440 | 190.2 | 0 | 0.75 | 0.76 | 84 | 12.5 | 2.51 | 125.53 | 2540 | 2540 | 128.99 | |
5840 | 180.5 | 0 | 0.73 | 0.74 | 83.2 | 13.7 | 2.36 | 124.92 | 2540 | 2540 | 128.99 | |
6160 | 174.4 | 0 | 0.73 | 0.73 | 80.5 | 15.6 | 2.3 | 123.56 | 2520 | 2520 | 128.99 |
3 | 3440 | 91.7 | 0 | 0.92 | 0.91 | 88.3 | 9 | 3.95 | 93.24 | 1790 | 2550 | 104.44 |
3920 | 191.7 | 0 | 0.88 | 0.91 | 88.3 | 9.8 | 4.23 | 121.42 | 2540 | 2540 | 125.72 | |
4560 | 191.7 | 0 | 0.74 | 0.76 | 87.9 | 9 | 3.35 | 121.54 | 2550 | 2540 | 128.98 | |
5080 | 191.7 | 0 | 0.74 | 0.76 | 86.7 | 10.5 | 2.73 | 124.45 | 2540 | 2540 | 128.99 | |
5560 | 187.2 | 0 | 0.76 | 0.76 | 84 | 12.5 | 2.45 | 124.56 | 2540 | 2540 | 128.99 | |
5960 | 176.7 | 0 | 0.73 | 0.75 | 83.2 | 13.7 | 2.35 | 125.25 | 2540 | 2530 | 128.99 | |
6320 | 168.4 | 0 | 0.72 | 0.73 | 82.4 | 14.1 | 2.34 | 124.98 | 2510 | 2510 | 128.99 | |
4 | 6200 | 12 | 0 | 1.99 | 0.95 | 19.9 | 77 | 4.89 | 122.02 | 2510 | 2510 | 119.75 |
Thanks
