Mk6 GTI Steering Wheel to Mk5 GTI
-GT-
Finland
Can someone help me?
I just fitted mk6 flat bottom steering wheel without buttons, but now i can't use the horn. Do i need slip ring revision C to make it work again? Or is there any other way to make it work?
jakethemoss
Denmark
Mercedes Sprinter
slipring and mayby also a mk 6 steering coloumn controller
-GT-
Finland
Thanks jakethemoss. I haven't yet done anything to my horn problem. And i'am wondering if it's possible to use mkv airbag cables or even airbag in mkvi steering wheel to make the horn working?
omeydz
BARGAIN RETROFITS!*PM ME*
S.E. London
Golf MK5 1.4
need a mk6 golf steering electrics module to make the horn work... if you have mf buttons, you want 1k0953549ch and C slipring
Altis
Ontario, Canada
Anyone willing to sell their MKV steering wheel?
I have an '07 Rabbit but theres a bunch of scratches on the steering wheel from the previous owner. It'd be nice to replace it with a GTI wheel rather than another boring Rabbit wheel.
If anyone would like to sell their stock wheel, please PM! Thanks!
cbx750p
Finally got mine installed yesterday.....also have the Climatronic from Mk6
Have issue with the left side switches....could not get them to switch radio station like on the Mark6 ! Only Volume works !
MK2G60
OC
Hi guys, new here on the board. Doing a MK6 GTI steering wheel swap in a MK5 GTI and got problems with the airbag, since MK5 is dual stage airbag and MK6 is single stage airbag. What did you do to get the waring light away and the error code?
Thanks for your help.
domlator
Croatia
We have a tiguan, having fitted the MK6 MFSW, installed a 1K0 953 549 CH, and used the exisitng 1K0 959 653 C slip ring, I can get all the MFSW buttons to work with the car (using code 0000734)...... however the module doesn't read the G85 steering angle sensor, fault code...
1 Fault Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
... Arhhhhhh - I suspect I need 1K0 953 549 BK, as my original was a type II midline, and think I need a type II highline
Jon
Hello m8,
Have you solved this.. Ive changed yesterday my wheel in MK5 and put a CH modul but i am getting shit load of errors.. And my wheel is hard like i don't have servo installed.. I think that's because of steering wheel angle sensor, it is needed to calibrate him again. But how do you solve problem above that you stated?
Thanks for any help.
Zach L
VR junkie
Austin, TX
Wow this is like the international forum in here! :D
THank you to everyone who's contributed ...tons of great info in this thread! And the Mk6 Climatronic install looks beautiful. I guess all you need is the radio surround that fits? Do the Mk5 wires plug right in?
Mark Five
Midlands
Hi
picking up my MkV gti next week. current non mfsw looking a bit scabby, although the rest of the interior is good.
I appreciate this thread has been "evolving" for some time, but I am keen to replace mfd2 for led mfd3, add the mk VI steering wheel, control box and upgrade the can gateway. I'm looking for someone to fit - but only found one place in Leicester (UK) to supply parts and one other who offers fitting only.
Any ideas?
jakethemoss
Denmark
Mercedes Sprinter
What partnumbers have you used?
after i changed my gateway from revision K to AH, i got my 729B bt back in the highline and the OK button suddenly works to end phone calls
dubsesd
Ottawa
just got my new wheel and parts. the airbag center seems to be pushed out more than normal though, will this change after i install it?
problemchild75
manchester
i fitted the wheel today along with mk6 ch module new slip ring and mk6 stalk. wheel works horn and buttons ok but I have yellow steering light on that i cant get off. I have tried the full left full right drive forward adaptation thingy about 20 times to no avail.
the fault codes I have are
Thursday,23,December,2010,12:10:13:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1K0
Scan: 01 03 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WV1ZZZ2KZ5X091434 Mileage: 126730km/78746miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001623597
Coding: 00884F020004100000000000000000000008FB075C
Shop #: WSC 35110 377 08192
VCID: 39722FBA4F0384D4
Part No: 2K2 955 119 B
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 35110
1 Fault Found
01506 - Bulb for Rear Fog; Right (L47)
012 - Electrical Fault in Circuit
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000533
Shop #: WSC 12345 123 12345
VCID: 7AF0F0B60A854FCC
Part No: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Coding: 00000130
Shop #: WSC 00000
1 Fault Found
00002 - Transmission Control Unit
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 2K0 920 941 C
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0000403
Shop #: WSC 00874 210 55459
VCID: 2952FFFABFA33454
1 Fault Found
00003 - Control Module
014 - Defective
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
Shop #: WSC 00000 000 00000
VCID: 3162179A97734C94
2 Faults Found
014 - Defective
Freeze Frame:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 6720 km
Temperature: 9.0°C
Voltage: 14.50 V
Voltage: 14.30 V
Any help would be very greatfully received
