Mk5 Xenon Headlights
NightWalker
Croatia
Hello people, so I have halogen typical headlights on my mk5 TDI and I wanna switch to Xenon headlights...So there is plenty of copy's of OEM headlights and I m not sure which ones are good to go with. Should I go with non original and with HID kit or buy OEM ones? Is it even possible to make OEM work with normal golf mk5 TDI? thanks in advance.
Gorg
Earth
I have the OEM already from factory, and I don't like them not bright at all,
I am thinking to shift to non OEM projector HID headlights but the only problem I am facing is the connector (from 12 to 10) and I am going to lose the levelling feature..
at least I am hoping for much brighter light
DeepBlue
NYC
Factory bulbs are not that great to be honest. Try different bulbs maybe? There a ton of options that will work with OEM headlights.
