Hello, I have a 2007 VW GTI, recently the trunk stopped opening. The Fob Button won't work, I've changed the trunk actuator latch, the interior trunk switch won't open it either. I do noticed there's one fuse (F15 - 10a) (engine bay fuse box) that doesn't turn on, even after swapping it with a new one, I've checked the connector for the Actuator and noticed only one of the pin slots has current running through it, not sure if that's correct or if all 4 need to have current.
Running out of things to trouble shoot, any help would be appreciated! Don't wanna spend hundreds to have someone change an inexpensive part if I can do it myself.
Thank you!
Thank you!
