mk5 on kw var 2
rysskii3
San Diego
Ride
GTI
You happen to know what size that washer nut is?
BTW is your rear spring upside down? I thought the flat side is suppose to be on the body of the car.. rear Perch
the rear perch is in the control arm, and the spring is on the right way. none of kw coils should have the perch on top. i have no idea on the size of the nut
