MK5 Jetta immobiliser issue
Sully114
GB
Golf VR6, Jetta S,
Hi I have an old 06 jetta thats been sitting for a few years and want to get it back on the road. Im having some weird electrical issues which I hope to get some help with to get the car started again. Presently the car is immobilized and starts and then shuts straight off. The instruments is pinging up loads of issues (immo active, steering wheel symbol, low oil pressure, low coolant, traction control is flashing contstantly) I have checked oil and coolant and levels are fine. I have various fault codes which I have been looking into below which could help track it down. So far I have replaced the ignition barrel and key reader,starter switch, new car battery, new key battery. Checked all fuses and relays and wiring to fuse box,/fuse panels under dash and cannot seem to find anything suspect although the symptoms im getting you would think a fuse/relay has gone or perhaps theres a wiring fault which im yet to find. I also checked the wiring under the battery tray and the main loom at the front of the engine which had previously been repaired when the rad fan would run constantly. I have yet to try recode a new key as the faults would indicated the steering column isnt getting any electrics Heres the auto scan from VCDS any help would really be appreciated.
VIN: WVWZZZ1KZ6M821795 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ6M821795 Mileage: 234950km-145991miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 KH HW: 03G 906 021 KH
Component: R4 1,9L EDC 000SG 8984
Revision: --H03--- Serial number: VWZ7Z0F3670020
Coding: 0000071
Shop #: WSC 00066 000 00000
VCID: 6FED66BB7E9D05EEAA-803B
VINID: 9E69EAAAA05BA867480811C91416B81496
5 Faults Found:
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Bin. Bits: 0 00 0
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 234959 km
Time Indication: 0
Date: 2000.00.00
Time: 04:23:35
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 11000100
Temperature: 13.5°C
Bin. Bits: 00110000
005712 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 234959 km
Time Indication: 0
Date: 2000.00.00
Time: 04:45:30
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 351.4 Nm
053273 - Control Module for Instrument Cluster
U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 234959 km
Time Indication: 0
Date: 2000.00.00
Time: 04:45:30
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11000100
Bin. Bits: 00000000
Bin. Bits: 00000000
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 234959 km
Time Indication: 0
Date: 2000.00.00
Time: 00:08:44
Freeze Frame:
RPM: 1008 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 64.7 %
Bin. Bits: 11000100
Mass Air / Rev.: 360.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 1 1 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021121
VCID: 71E960C368A9131EBC-8025
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
01486 - System Function Test Activated
000 - -
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DP
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 75E154D31CC13F3E60-8021
2 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
008 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000317846
Coding: E4010E2700041500000A00000F000000000859035C
VCID: 2A5BB7AF85FF20C63D-807F
Subsystem 1 - Part No: 1K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00066
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00066
No fault code found.
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: 2K AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD0AMC26
Coding: 0012875
VCID: 3B7582EB7A65A94E56-806F
Subsystem 1 - Serial number: 6332MSME0D274A1BJ
Subsystem 2 - Serial number: 6342MSME0E7042111
Subsystem 3 - Serial number: 6351HSME094915274
Subsystem 4 - Serial number: 6361HSME094D10285
1 Fault Found:
004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000011
VCID: 76E353DF01C7342669-8023
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 962 G
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0022401
Shop #: WSC 00278 210 82059
VCID: 2F6DA6BBBE1D45EEEA-807B
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001062202496
Coding: 3D3F0B40071003
Shop #: WSC 00066 123 12345
1 Fault Found:
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 188
Time Indication: 15
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
1 Fault Found:
01176 - Key
000 - -
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2378
Coding: 0000756
VCID: 366393DF41477426A9-8063
1 Fault Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3467A9D7573B663697-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01D802087F2D8405485FC69011A0
VCID: 79F958E330D95B5E04-802D
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000756
VCID: 377D9EDB464D8D2EB2-8063
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0020400
VCID: 3365AACB5235610E8E-8067
2 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2434
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51BCB3B41137FED8-8079
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:24)--------------------------
