reverend_sean
- Pittsburgh
I moved this thread from the For Sale section just to put the continued discussion in the correct location.
Hey all - these did arrive and I am in the process of installing them. I have done a few test fits and they seem to bolt up nicely. The caliper sticks out 33mm from then hub face so Austins definitely won't fit. My summer wheels are BBS SRs in 18x8 35et and they don't fit either. They are SUPER close, and if I run a 5mm spacer I think they will work fine for a daily. For the track I am going to run 18x8.5 32et TSWs and they should clear no problem at all with that offset and wheel design. Pad choices are near endless as these take the same pad as 4 piston STI Brembos and LOTS of other performance cars.
Concerns:
1) These calipers come from the Renault Megane RS 275 (really any Megane RS from like '08-'16 I believe). That car's front rotors are 340x28mm and the opening for the rotor in the caliper is only 32mm wide. It doesn't touch anywhere, but obviously that only leaves 1mm on either side for the GTI's 30mm wide rotor. We shall see how they work! Those pics showing how close the caliper is to the rotor are a little misleading. I didn't have the caliper bolted on tightly and there is a little play as far as the positioning of the caliper. I just need to get them centered perfectly before torquing them down.
2) I don't know what torque value I can use for the bolts that thread into the aluminum bracket. The stock caliper mounting torque is 200Nm, but I have to think that is too much for the new aluminum brackets. I guess if they strip they will be good candidates for steel helicoils, lol. If anyone knows more about aluminum (it is supposedly to be d16t aluminum if that means anything to you - U.S. equivalent is 2024-T6) and how I might determine a torque value for the bolts, feel free to chime in. EDIT - found a site called futek.com that will help me calculate the torque values.
Once I get them mounted and working I will let you all know how it is going. I have 2 track days planned before May, so it may be a while till I have a solid opinion. If they work out well, I'd be happy to have the brackets recreated for anyone interested. I am not sure if other US market Brembos mount the same way, but if so, it could be a nice brake upgrade option for MK7 cars.
Concerns:
