Meat's Brake DIY (w/ thanks to DanGSR)
07Noside
x
yea I've bought two different tools I wasn't sure about opening the bleeder the valve or not as I didn't want to lose to much. Both the fronts were a peace of cake and I've really been musceling the rears and they hardly even budged. I even took a wrench to the handle of the one trying to get more leverage and still no go I'm going to give the bleeders a shot. Am I going ot have to refill it with new break fluid if I only bleed a little bit out or should I be fine?
07Noside
x
the bleeder is the valve covered by the nipple on the break caliper its self correct. i dont have a bleeder but i can simply attach a hose to it so thefuid doesnt go every where and all help is great right now cuz im stuck with no rears
HipToss
Behind the iron sights
NY - Goshen
2008 GTI
This is an amazing write up. Have only done drums in my life on my muscle cars. Will be upgrading pads soon, and will use this as a DIY. Any tips I should know about?
Also looks like I need to by a piston reset tool finally! :smile:
SloppySRT
Taste the Rainbow!
Tampa, FL
lol I wonder how 07Noside is doing with his brake job :biggrin:
Nerdavison
Nerd with Speed addiction
Tucson, AZ
with the rear pads helps to clean off and spray a little lube on the boot for the piston so it doesnt got caught and twist and rip.
tranceporter
F**K YOU CAM FOLLOWERS
NY | NJ
'08 BMP GTI
we did my pads last night. we had to twist the rear pistons with a channel lock wrench because we didn't have the correct tool. grease came out as we were torquing it down. nothing else leaking, i'm assuming it's normal. unfortunately i think we got air in the lines. the only way the car stops is by pumping the brake :lol: i'm going to bleed the lines today and hopefully it'll solve that problem.
