should be used ALL THE TIME
Thanks Dan :thumbsup:
do one line at a time
it doesn't drip fast enough that you have to worry
For the SS lines, yea as Dan GSD said do one at a time and keep the cap on. I did all 4 without needing to top up the fluid. Make sure your line up the fittings properly though. That was not explained too well in the diy. There are slits for them to go into and slide up. Look at how and where the clip is and make sure you put it back in the same way to keep the line there. Overall it was pretty simple once I figured it out.
its a 15mm
but you need a thin one
Just did the rears yesterday. Those M14 bolts were a pain to remove. Mine was kinda rusted from the Chicago winter.
