ME & MY MKV Build! (Fun, Tough & Cost)
Mostic
Egypt
VW Scirocco
What did you use to flash the revision "Q" software?
I have the Kufatec unit, but I can't see my oil temperature either.
I used ODIS tool to flash the Q revision.
Don’t know much info about the Kufatec tool.
If the oil temp sensor is installed and connected to the ECU & Cluster then let me know the existed SW version you have.
Nitrous1024
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Coding: 040300101C070160
Shop #: WSC 66565 257 00032
VCID: 354FD8585CDD5EECC7-8060
1 Fault Found:
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 178741 km
Time Indication: 0
Date: 2000.00.00
Time: 08:06:53
Freeze Frame:
RPM: 759 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Readiness: 0110 0001
I don't "know" if the sensor is actually installed in my MK5 GTI, since I don't know where to check the sensor.
Is your copy of ODIS a genuine one or a clone? I'm trying to determine if the ones I see on eBay, can do software updates to the modules themselves.
Mostic
Egypt
VW Scirocco
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 178741 km
Time Indication: 0
Date: 2000.00.00
Time: 08:06:53
Freeze Frame:
RPM: 759 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Voltage: 13.462 V
Buy this tool it works with me...
http://www.buyobdii.com/vas-6154-odis-vw-audi-skoda-diagnostic-tool-p-1599.html
Once you have it, I will send you the Q version.
The oil level/temp sensor located in the oil pan.
Nitrous1024
In that case: Yes, I have that sensor bolted to my oil pan. I thought it was the oil level sensor to warn me if the oil level is low. I'm going to buy what you sent me right now.
Edit: I just bought it. It will take a few weeks to arrive to me in Jamaica.
Mostic
Egypt
VW Scirocco
I will upload later the Odis Engineering and send you the link to download it so you can flash any .SGO file you may want/need.
Nitrous1024
I have this item in hand right now. I'm asking you for the Q version.
Why would VW provide me the sensor if there was no way for the driver (or the ECU to use it)?
Would flashing the "Q" version trip my immobiliser or cause me to lose my custom software tune?
Mostic
Egypt
VW Scirocco
Congratulations for receiving the tool.
I am on vacation now, I will send you the Q version once back.
Don’t know the reason for VW, but I am enjoying seeing the oil temp on my MFD and it’s really nice.
Flashing the Q version shouldn’t impact the immobilizer but for sure you will lose any tune you have on the ECU!
Nitrous1024
I've been playing with the tool last night (not the way that it sounds). My issue is that I can't actually use the "Flashing" option from the copy of the ODIS software I received, as I'd need to have a valid login. I was hoping to simply select a "local" file on my laptop like the one you would provide for me.
Please do enjoy your vacation.
Mostic
Egypt
VW Scirocco
Don’t worry, once I back I will send you the link for an easy Odis tool. It’s the Odis Engineering :)
Nitrous1024
Thanks for your assistance. I got a copy of Odis Engineering. My issue is that I don't know "where" to get the updated *.*SGO files for all my modules below. My version of the software didn't come with these files although I imported numerous "projects" during the post-installation process.
I'm leaving a snippet of my existing hardware for your perusal in two parts, as it exceeds the 1,000 character limit.
ODIS Engineering
Ergebnisprotokoll
06.07.2019 21:26:16
Workshop code:
Version:
00000 219 00000
Version number: TEMR195_P1-20151120
Release: 6.6.1
Diagnostic kernel: 310.5.3 (Volkswagen AG)
MCD: 3.0.0
ECF: 26.2.0 (20151015)
PDU-API: 13.0.0
Measurement type / measurement location
VIN:
WVWZZZ1KZ8W111078
System environment
Login account: Matthew
PC name: MATTHEW
Operating system: Windows_NT
Processor: Intel64 Family 6 Model 61 Stepping 4, GenuineIntel
RAM: 3145272
Diagnostic hardware: VAS6154
Vehicle
VIN: WVWZZZ1KZ8W111078
Mileage: 185490 km
MCD project: VW35x_1K_7 (Engineering)
MCD project version: 2.7.5_141204
Content
Components List
0001 - Engine Control Module 1
001 Identification 006 Read coding
0002 - Transmission Control Module
0003 - Brakes 1
0008 - Air Conditioning
001 Identification
0009 - Central Electrics
0015 - Airbag
0016 - Steering Column Electronics
0017 - Dash Board
001 Identification
0019 - Gateway
0025 - Immobilizer
001 Identification
0042 - Door Electronics Driver Side
0044 - Steering Assistance
001 Identification
0046 - Central Module Comfort System
0052 - Door Electronics Passenger Side
0055 - Headlight Regulation
0056 - Radio
0077 - Telephone
001 Identification
Communication data
ECU: 0019 - Gateway
06.07.2019 21:26:17
LL_GatewKWP2000CAN20
Master - 001 Identification
06.07.2019 21:26:17 Top^
System description J533 Gateway H07
Software version 0052
Hardware version H07
VW/Audi part number 1K0907530L
Hardware part number 1K0907951
Coding ED811F060006020001
Master - 006 Read coding
06.07.2019 21:26:18 Top^
Byte00:
1110 1101 ($ED)
Byte01:
1000 0001 ($81)
Byte02:
0001 1111 ($1F)
Byte03:
0000 0110 ($06)
Byte04:
0000 0000 ($00)
Byte05:
0000 0110 ($06)
Byte06:
0000 0010 ($02)
Byte07:
0000 0000 ($00)
Byte08:
0000 0001 ($01)
ECU: 0001 - Engine Control Module 1
06.07.2019 21:26:18
LL_EnginContrModul1KWP2000CAN20
System description 2.0l R4/4V TFSI
Software version 0020
Hardware version H16
VW/Audi part number 1K0907115R
Hardware part number 8P0907115B
Coding 040300101C070160
06.07.2019 21:26:19 Top^
Byte00:
0000 0100 ($04)
Byte01:
0000 0011 ($03)
Byte02:
0000 0000 ($00)
Byte03:
0001 0000 ($10)
Byte04:
0001 1100 ($1C)
Byte05:
0000 0111 ($07)
Byte06:
0000 0001 ($01)
Byte07:
0110 0000 ($60)
ECU: 0002 - Transmission Control Module
06.07.2019 21:26:19
LL_TransContrModulKWP2000CAN20
System description GSG DSG 082
Software version 1407
Hardware version 108
VW/Audi part number 02E300044J
Hardware part number 02E927770AD
Coding 20
06.07.2019 21:26:21 Top^
Byte00:
0011 0010 ($32)
Byte01:
0011 0000 ($30)
ECU: 0003 - Brakes 1
06.07.2019 21:26:21
LL_Brake1KWP2000CAN20
System description ESP FRONT MK60
Software version 0101
Hardware version H11
VW/Audi part number 1K0907379AC
Hardware part number 1K0907379AC
Coding 4738
06.07.2019 21:26:24 Top^
Byte00:
0011 0100 ($34)
Byte01:
0011 0111 ($37)
Byte02:
0011 0011 ($33)
Byte03:
0011 1000 ($38)
ECU: 0008 - Air Conditioning
06.07.2019 21:26:24
LL_AirCondiKWP2000CAN20
System description ClimatronicPQ35 120
Software version 1111
Hardware version 120
VW/Audi part number 1K0907044BS
Hardware part number 1K0907044BS
Coding ?
ECU: 0009 - Central Electrics
06.07.2019 21:26:32
LL_CentrElectKWP2000CAN20
06.07.2019 21:26:26 Top^
System description Bordnetz-SG H54
Software version 2202
Hardware version H54
VW/Audi part number 3C0937049AJ
Hardware part number 3C0937049AJ
Coding F78F8F270004150047140A001400008000193C075C10010C000000000000
06.07.2019 21:26:32 Top^
Byte00:
1111 0111 ($F7)
Byte01:
1000 1111 ($8F)
Byte02:
1000 1111 ($8F)
Byte03:
0010 0111 ($27)
Byte04:
0000 0000 ($00)
Byte05:
0000 0100 ($04)
Byte06:
0001 0101 ($15)
Byte07:
0000 0000 ($00)
Byte08:
0100 0111 ($47)
Byte09:
0001 0100 ($14)
Byte10:
0000 1010 ($0A)
Byte11:
0000 0000 ($00)
Byte12:
0001 0100 ($14)
Byte13:
0000 0000 ($00)
Byte14:
0000 0000 ($00)
Byte15:
1000 0000 ($80)
Byte16:
0000 0000 ($00)
Byte17:
0001 1001 ($19)
Byte18:
0011 1100 ($3C)
Byte19:
0000 0111 ($07)
Byte20:
0101 1100 ($5C)
Byte21:
0001 0000 ($10)
Byte22:
0000 0001 ($01)
Byte23:
0000 1100 ($0C)
Byte24:
0000 0000 ($00)
Byte25:
0000 0000 ($00)
Byte26:
0000 0000 ($00)
Byte27:
0000 0000 ($00)
Byte28:
0000 0000 ($00)
Byte29:
0000 0000 ($00)
Subsystem - 001 Identification:
Subsystem number 1
System description Wischer 300807 021
Software version 0501
Hardware version ---
VW/Audi part number 1K2955119E
Coding 38837
Subsystem number 2
System description RLS 130907 046
Software version 0204
VW/Audi part number 1K0955559AF
Coding 208933
Subsystem - 006 Read coding: Wischer 300807 021
Byte00:
0011 0011 ($33)
Byte01:
0011 1000 ($38)
Byte02:
0011 1000 ($38)
Byte03:
0011 0011 ($33)
Byte04:
0011 0111 ($37)
Subsystem - 006 Read coding: RLS 130907 046
Byte00:
0011 0010 ($32)
Byte01:
0011 0000 ($30)
Byte02:
0011 1000 ($38)
Byte03:
0011 1001 ($39)
Byte04:
0011 0011 ($33)
Byte05:
0011 0011 ($33)
ECU: 0015 - Airbag
06.07.2019 21:26:32
LL_AirbaKWP2000CAN20
System description 3A AIRBAG VW8 020
Software version 2300
Hardware version 020
VW/Audi part number 1K0909605T
Hardware part number 1K0909605T
Coding 13121
06.07.2019 21:26:34 Top^
Byte00:
0011 0001 ($31)
Byte01:
0011 0011 ($33)
Byte02:
0011 0001 ($31)
Byte03:
0011 0010 ($32)
Byte04:
0011 0001 ($31)
ECU: 0016 - Steering Column Electronics
06.07.2019 21:26:36
LL_SteerColumElectKWP2000CAN20
System description J0527 036
Software version 0070
VW/Audi part number 1K0953549AQ
Hardware part number 1K0953549AQ
Coding 12122
06.07.2019 21:26:36 Top^
Byte00:
0011 0001 ($31)
Byte01:
0011 0010 ($32)
Byte02:
0011 0001 ($31)
Byte03:
0011 0010 ($32)
Byte04:
0011 0010 ($32)
Subsystem number 1
System description E0221 002
Software version 0010
VW/Audi part number XXXXXXXXXXX
Coding ?
ECU: 0017 - Dash Board
06.07.2019 21:26:36
LL_DashBoardKWP2000CAN20
System description KOMBIINSTRUMENT VDD
Software version 1216
VW/Audi part number 1K6920974
Hardware part number 1K6920974
Coding 6103
ECU: 0025 - Immobilizer
06.07.2019 21:26:41
LL_ImmobKWP2000CAN20
06.07.2019 21:26:41 Top^
System description IMMO VDD
Hardware version 002
Coding ?
ECU: 0042 - Door Electronics Driver Side
06.07.2019 21:26:44
LL_DoorElectDriveSideKWP2000CAN20
06.07.2019 21:26:44 Top^
System description Tuer-SG 006
Software version 120B
VW/Audi part number 1K0959701M
Hardware part number 1K0959701M
Coding 564
06.07.2019 21:26:46 Top^
Byte00:
0011 0101 ($35)
Byte01:
0011 0110 ($36)
Byte02:
0011 0100 ($34)
Nitrous1024
Part 2
ECU: 0044 - Steering Assistance
06.07.2019 21:26:46
LL_SteerAssisKWP2000CAN20
System description EPS_ZFLS Kl. 207
Software version 3305
Hardware version H22
VW/Audi part number 1K0909144P
Hardware part number ------------
Coding ?
ECU: 0046 - Central Module Comfort System
06.07.2019 21:26:52
LL_CentrModulComfoSysteKWP2000CAN20
06.07.2019 21:26:48 Top^
System description KSG PQ35 G2 020
VW/Audi part number 1K0959433BT
Hardware part number 1K0959433BT
Coding 989002085103007F42040F0FF00A5A0690BC00
06.07.2019 21:26:54 Top^
Byte00:
1001 1000 ($98)
Byte01:
1001 0000 ($90)
Byte02:
0000 0010 ($02)
Byte03:
0000 1000 ($08)
Byte04:
0101 0001 ($51)
Byte05:
0000 0011 ($03)
Byte06:
0000 0000 ($00)
Byte07:
0111 1111 ($7F)
Byte08:
0100 0010 ($42)
Byte09:
0000 0100 ($04)
Byte10:
0000 1111 ($0F)
Byte11:
0000 1111 ($0F)
Byte12:
1111 0000 ($F0)
Byte13:
0000 1010 ($0A)
Byte14:
0101 1010 ($5A)
Byte15:
0000 0110 ($06)
Byte16:
1001 0000 ($90)
Byte17:
1011 1100 ($BC)
Byte18:
0000 0000 ($00)
Subsystem number 1
System description Sounder No Answer
Software version
VW/Audi part number
Coding ?
Subsystem number 2
System description NGS n.mounted
Software version
VW/Audi part number
Coding ?
Subsystem number 3
System description IRUE n.mounted
Software version
VW/Audi part number
Coding ?
ECU: 0052 - Door Electronics Passenger Side
06.07.2019 21:26:54
LL_DoorElectPasseSideKWP2000CAN20
VW/Audi part number 1K0959702M
Hardware part number 1K0959702M
Coding 564
06.07.2019 21:26:56 Top^
Byte00:
0011 0101 ($35)
Byte01:
0011 0110 ($36)
Byte02:
0011 0100 ($34)
ECU: 0055 - Headlight Regulation
06.07.2019 21:26:56
LL_HeadlRegulKWP2000CAN20
System description Dynamische LWR
Software version 0003
VW/Audi part number 1T0907357
Coding 3
06.07.2019 21:26:58 Top^
Byte00:
0011 0011 ($33)
ECU: 0056 - Radio
06.07.2019 21:26:58
LL_RadioKWP2000CAN20
System description Radio Prem-8
Software version 0016
Hardware version H02
VW/Audi part number 1K0035180AE
Hardware part number 1K0035180AE
Coding 01000401000005
06.07.2019 21:27:01 Top^
Byte00:
0000 0001 ($01)
Byte01:
0000 0000 ($00)
Byte02:
0000 0100 ($04)
Byte03:
0000 0001 ($01)
Byte04:
0000 0000 ($00)
Byte05:
0000 0000 ($00)
Byte06:
0000 0101 ($05)
ECU: 0077 - Telephone
06.07.2019 21:27:01
Telep
Control module not responding
Nitrous1024
Thank you. I see your file. I'm going to download it.
I'm afraid to lose my current Stage2 flash (based on my "R" ECU version).
Then I brick the ECU trying to flash "that" on top of the "Q" firmware I would receive from you.
Can you explain how it works for these ECU types? My understanding is that the software simply has the data in slightly diferent "storage" areas in ROM.
Also, you have triggered my greed to find out what other firmware updates are available for the various component of my car (such as radio, and ABS unit). I don't know "which SGO files to ask you for.
