clockwise33
New York Giants Fanatic
- NJ
Ever since my cam chain tensioner replacement / K04 install 5,000 miles ago I've had oil leaking down the back of the motor on the trans side. I first uninstalled/reinstalled the cam chain cover with another new gasket, then updated the vacuum pump to the new design that fixes the oil leak there.
Still had leaking in the same area.
I think I have narrowed it down to the VC gasket, specifically the rear driver side corner. The gasket on there is new since the K04 install, so I have pulled it and cleaned the area twice already and I am still finding motor oil back there where the VC bolts onto the head. The engine never leaked a drop until I did the chain tension and K04 swap. So I am going to the dealer later to pick up another new gasket.
Is there a trick to get this thing to seal? Should I be installing it dry or oiled?
