Key fob does not work
That_slow_mk5
2007 Volkswagen GTI
Hi so this is my first time posting here.
I recently became the owner of a 2007 gti. The car had a couple of issues mostly cosmetic but one major issue was that the driver side door would not lock.
So the place i bought it from replaced the door latch. Now the door locks but the key fob itself still does not lock or unlock the car.
So big deal, it honestly doesn't bother me using the key to get in and out of the car. The only issue is when i lock the car the alarm arms as it should, but when i unlock it the alarm stays armed and when i open the door the alarm goes off like crazy.
I got a hex V2 cable from Ross tech to see if I could pair the key fob, but no luck.
I'm new to Vagcom so i don't want to start poking around stuff i don't understand. What should I do? Is there a way to deactivate the alarm? Do i need to get a new key?
I did check the battery and it was fine but i replaced it just in case.
The key fob part number is HLO 1K0 959 753 P
Not sure if it's the right key as it's the only one that came with the car.
GTI's
MD
First thing you should do with your new cable is to run an Auto Scan on this car and save that baseline scan in a safe place. You can then post up the complete Auto Scan here in your post so the people on the forum can have a look at it.
That_slow_mk5
2007 Volkswagen GTI
This is the initial autoscan.
Tuesday,25,May,2021,19:17:46:15818
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWFV71K47W014995 License Plate: QZEY35
Mileage: 231610km-143915mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWFV71K47W014995 Mileage: 231610km-143915miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH14--- Serial number: VWZ7Z0F4068266
Coding: 0403010A1C070160
Shop #: WSC 05226 444 84503
VCID: 2B030D553F06ECF30A1-807E
No fault code found.
Readiness: 0000 0100
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1120
Revision: 04507000 Serial number: 00000609301165
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1471B6A98278530B3BB-8040
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
Shop #: WSC 01279 785 00200
VCID: 73B3D535A7B6F433821-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FP
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 77ABE125B3CE9813BE9-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AA HW: 3C0 937 049 AA
Component: Bordnetz-SG H45 1402
Revision: 00H45000 Serial number: 00000002289974
Coding: 178F0F214004180000140000001400000028770B5C0000
Shop #: WSC 28609 001 1048576
VCID: 6889B259EE7007EB273-803C
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 220506 020 0501
Coding: 00038805
Shop #: WSC 28609
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E3018161
VCID: 2A0D085130FCF5FBF17-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:07:19
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 Q HW: 1K0 909 605 Q
Component: 5L AIRBAG VW8R 033 7900
Revision: 04033000 Serial number: 0038LD092H5Z
Coding: 0013644
VCID: 3A2D3811C05C457B817-806E
Subsystem 1 - Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Subsystem 2 - Serial number: 6332MSME0F3D084DR
Subsystem 3 - Serial number: 6342MSME112747521
Subsystem 4 - Serial number: 6352QSME0B2D3777R
Subsystem 5 - Serial number: 6362QSME0F777925U
Subsystem 6 - Serial number: 63727SME0A3E405C8
Subsystem 7 - Serial number: 63827SME0A3E5C5DN
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0012122
VCID: 7AADF81180DC857BC17-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
008 - Implausible Signal - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F4068266
Coding: 0007203
Shop #: WSC 01287 785 00200
VCID: 313F1F3D1D2A862330D-8064
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 131206 km
Time Indication: 0
Date: 2000.00.00
Time: 00:16:05
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065180824
Coding: 7F0F03600F000000
VCID: 2C010E493A08EBCB03B-8078
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1225223T1DW202
VCID: 7DA7F30D91F2B243E45-8028
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0967
Coding: 0001077
VCID: 38292219FE50576B773-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 34311629E238B30B5BB-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A0488BC00
VCID: 74B1D629A2B8F30B9BB-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
01179 - Incorrect Key Programming
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:09:14
00896 - Trunk Lock Unit (F256)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 3
Reset counter: 139
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:13:40
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 004 0953
Coding: 0001076
VCID: 392F271DC55A4E6388D-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 018 0035
Revision: 00018000 Serial number: VWZ5Z7G2154874
Coding: 0040401
Shop #: WSC 05072 444 59098
VCID: 290FF75D35FAFEE3F8D-807C
2 Faults Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:51
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:51
End----------(Elapsed Time: 01:17, VBatt start/end: 12.5V/12.5V)-----------
GTI's
MD
www.Ross-Tech.com
Coding: 0000020
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 28609
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:07:19
Coding: 0013644
Coding: 0012122
1 Fault Found:
Coding: 0007203
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 131206 km
Time Indication: 0
Date: 2000.00.00
Time: 00:16:05
Coding: 0001077
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:09:14
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 139
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:13:40
Coding: 0001076
Coding: 0000003
Coding: 0040401
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:51
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 231601 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:51
Clear all the trouble codes and rescan and lets see what comes back, some of the fault codes happened only once and miles ago.
09 that is for sirius sat radio you will always get that dct unless you have an active subscription to the service.
17 happened one time and 100404 km ago.
That_slow_mk5
2007 Volkswagen GTI
Wednesday,26,May,2021,10:08:16:15818
www.Ross-Tech.com
16-Steering wheel -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
56-Radio -- Status: OK 0000
Coding: 0000020
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 28609
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 99
Mileage: 231615 km
Time Indication: 0
Date: 2000.00.00
Time: 00:03:46
Coding: 0013644
Coding: 0012122
Coding: 0007203
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 131206 km
Time Indication: 0
Date: 2000.00.00
Time: 00:16:05
Coding: 0001077
Coding: 0001076
Coding: 0000003
Coding: 0040401
End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.3V)-----------
That_slow_mk5
2007 Volkswagen GTI
Not sure if it helps but i went to 46- central conv. And was looking at measuring block 019 and 020.
019 states that the 1st, 2nd, 3rd,and 4th alarm triggers are not installed.
020 states that the 1st, 2nd, 3rd, and 4th alarm sources are at 0.
GTI's
MD
019 is for interior monitoring which this car does hot have so that is why it state not installed.
020 indicates that the drivers door is what has set off the alarm.
If you move your cursor over the fields you will sometime get a popup window that gives more info on that field.
You can do an adaptation with Vcds for the key fobs that have the buttons to remote control match to the car. It is in module 46 adaptations.
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Comfort_System#Adaptation
Video of procedure
That_slow_mk5
2007 Volkswagen GTI
Ok so turns out it was the fob itself that was bad. I ordered a new remote and then i used vcds to adapt it to the car and now it works perfect. Thank you for the input and also helping me understand vcds a little more.
