Ironshade 6mt swap
Ironshade
Atlanta Ga
Was about to post, "what a poseur, putting a 6spd knob on a tsi" šŸ˜‚
Usually go to new posts and open all the ones in interested in, in a new tab and the site takes me to the newest post. So sometimes I don't know which thread I'm reading...then I saw it was you.
How does it feel?
Lol, so far so good. I only have 70miles on the clutch but i did a little WOT in 3rd to log if i have afr issue. It looked ok, hopefully it stays that way tho. Map 0 no stack just apr is38 file.
MonkeyMD
How does your is38 fell compared to stage 1, if you were ever stage 1. Guess I was expecting more. Just from seat of the pants, feels a little quicker. Also barely spun tires in 2nd gear. Granted I have 265's, but still. Thinking I want to stack with jb4, but not sure how far you can take it without hpfp
Ironshade
Atlanta Ga
Well i run 28psi stacked on meth on is38. Car hauls ass. Def a 120+ trap car. I run 7-8psi over apr is38 file. There should be a thread on here called ironshadesā€™s car that has all my info from is38 to is20 and what not. But stg 1 to is38 is completely diff animals... even in 3rd i can melt my tires if i want to. Heres a log. Keep in mind this log is from 100ā€™ outside temps over 4000da.
Ironshade
Atlanta Ga
Another little 2nd gear log. Still breaking in the clutch but still curious how its all going afr wise
MeltedSolid
Autocross Newbie
San Francisco Bay Area
'15 Golf, e36 328i
It says well below 15, so it looks good to me. Can you add the gear indicator to your logs?
PLF8593
Philly
19 Alltrack 6MT
The gearing in my MK6 GTI was my favorite of the 3 manuals Iā€™ve owned. The most ā€œnarrow ratiosā€ Iā€™ve had. 6th was spinning ~3K at 75 mph, and the ratios were so tight from 1-4 that it played super well with the turbo, and the underpowered 200HP/207TQ. Basically imperceptible turbo lag. Both MK7ā€™s Iā€™ve had had much less sporty manual gearing, clearly more efficiency oriented.
Iā€™ve been thinking about a future MK6 Golf R 6MT swap into my Alltrack, since it *should* bolt right up. Iā€™d imagine the MK6 Golf R had even sportier gearing than the GTI, considering it had AWD to take advantage of even more explosive 1st2nd gear pulls.
Ironshade
Atlanta Ga
Did another 2nd gear log. You can see where it went from seeing 2nd to going to 9th on log
MeltedSolid
Autocross Newbie
'15 Golf, e36 328i
Nice, all that matters with the log is if the AFR has a change when you transition from in gear to out of gear, so you look good to me.
Ironshade
Atlanta Ga
yeah, thats what ive been watching the whole time is afr. so far so good tho. as far as coding, know of anyway to removed the gear on dash completely? I was thinking of just putting a sticker over it and leaving it in 5mt mode, because im tired of looking at it
MeltedSolid
Autocross Newbie
'15 Golf, e36 328i
Not as far as I know. I would prefer to have it gone or something too.
Ironshade
Atlanta Ga
Gotcha, i think im just going to put a sticker over it and forget about it.. i never used boost by gear as it is. So another couple days of driving and weā€™ll see what dragy 60-100 is. Previous best is 4.78 60-100mph.
Ironshade
Atlanta Ga
Did 2 logs.. 3rd gear ac on like a noob. 4200da. No meth no stack, full tank, roof rack and girlfriend in car. Car hauled ass, Did 1 dragy run 5.65 60-100. Considering the DA and apr only Iā€™m extremely happy. Guessing iā€™ll see ~4.4 or so 60-100s with meth stacked.
Ironshade
Atlanta Ga
Before I turn it up again. Spark plugs and oil change. Figured id do a compression check as well. 125k miles on clock.
