projekt.kieru
Inspired.
- Earth
sub`ed
hey jetTurbo, i was so happy when you first made this thread, it has helped calm some of the FTP threads, anyway i recently became aware of another light mod w/ vag-com i don't think you have covered yet, having the turn signals (front) stay on with the parking lights to give a "solid bar" look, reading some threads on the tex about it. looks good, but should come with a disclaimer that if the brightness is set too high it could melt certain things
Is there a way to turn-off the turn signals when the parking lights are or when the headlights are on? I just want them when I need to signal and that's it.
Just found this thread and it's great. However, I was wondering how many of you have had problems at the VW dealer if you changed your settings to the UK/EU in order to disable the DRLs?
You do not need to change instrument country setting to disable DRL,
you can do that just fine with US instruments.
Both posts #42 and #43 deal with that topic,
i.e. neither of us had any issues at the dealer.
Since the day my car was received,
it has never had US instruments setting (to eliminate the nav nag)
and the local dealer has never once commented on it.
And the dealer has cleared DTCs on multiple occasions,
so I know they have hooked up to it.
As for post # 12, I suspect there may be some other reason for the issue
and the instrument settings is wrongly being blamed.
In fact, a chipped ECU does not prevent the dealer from hooking up,
head unit anomalies are a more likely cause, they are snowing that poor guy.
