I have a torqbyte PM3 to order soon. I do have a USP TTRS tank pump that I dislike due to just the incorrect fuel level readings. I found I cannot swap the oem level sending unit from its basket to the TTRS basket. So I took the TTRS pump out of its basket to attempt to install it into the oem basket later if needed. But I first wanted to know if anyone has successfully installed one of these into the oem basket: http://www.highflowfuel.com/ag-1305...5305-automotive-2007-volkswagen-gti-2-0l.html
1st choice - is that the PM3 will work with the oem LPFP as I believe it will because a pump upgrade shouldn't make any difference without adjustability of the tune or extra amps provided by the PM3.
2nd choice - I need help with knowing how to safely remove the oem pump, so as to not destroy the oem basket, so I can install the now removed TTRS pump into the oem basket
3rd choice - install the 265 Lph into the oem basket...or better and just as simple alternative.
The PM3 may work just fine with the oem LPFP but, if not, my hope is to get one of the two options above(TTRS or 265Lph) to work.
