Immobilizer issue
EndriMK5
Michigan
MK5 GTI
So I have a 2008 MK5 GTI and I lost my key for it the problem I am facing now is that I have another key I got from the dealer so I can crank the car but will not start due to immobilizer also the key cannot be programed because the dealer said that I need to replace my ECU and my cluster now that is more than $3000 and I don't have that type of money to throw at that car I have been researching and there are ways to turn off the immobilizer but it seems a lot harder to do with the mk5 and up. I need some help or links as to where I can send the ECU so they can do it for me or if you have any ideas please send me anything you can think of thank you so much
GTI's
MD
That is what makes no sense why the need for a new Ecu & cluster if they were original to the car and were working just fine before and all you did was lose the last key for this car. A key fob cut and setup for programing based on your VIN is like a few hundred dollars plus the tow cost to a dealer for finish programing.
Remember that if you do go the Immo delete route you are losing the theft protection feature & if the key is found by someone they can drive away with the car.
EndriMK5
Michigan
MK5 GTI
UPDATE: The dealer tried to scam me for almost $4000 I had someone come to the dealer to program my key, turns out that the dealer did not even try to program the new key
