HPA instake manifold with DPI W/M bungs.
Das Gespenst
Glen Ellyn
Anyone here have HPA drill and tap the meth bungs on their manifold. For some reason I seem to remember people having clearance issues with the nozzles. Can anyone confirm there is or is not an issue with there bung placement? Getting my parts list together for my BT setup and thinking about going with HPA for the intake mani.
GIACUser
Master Wallet Mechanic
SoCal
I don't think there is an issue, can't see why there would be. In their v1 they did tig weld in bungs and in v2 the pics I see are just drill and tap. The newer v2 castings have what appears to be a thicker section on the underside of the runner where they put the bungs before (v1) and where I intend to put mine. Probably would have been easier to keep the IE one I had it was already drilled and tapped.
josein06gli
GLI OWNER
San Diego, Ca
Ride
VW Jetta GLI
What he said. The IE would be a lot easier to put on. Plus the ie uses actual gaskets. The IE you need to use permatex to seal the manifold to the head and tb to manifold.
GIACUser
SoCal
When I got the IE and was going to use it some folks gave me bad feedback on performance, was it true, it was too new to know. I went HPA since they have high powered cars running around already, so I know it can work.
GIACUser
SoCal
Pics to illustrate differences between v1 and v2 and direct inject. Based on my reading the direct inject solutions are custom orders from HPA.
Pic 1 - HPA v1
Pic 2 - HPA v1 with HPA installed direct inject - bung welded in
Pic 3 - HPA v2
Pic 4 - HPA v2 - with factory supplied direct inject - drilled and tapped, no bung welded in.
Das Gespenst
Glen Ellyn
Can I install this and notice a difference or do I need to tune?
This would actually hurt performance for anything K04 and under. You need to be running a decent size turbo to actually take advantage of it. It also doesn't have runner flaps so the correct tune would be needed to run it.
