DIY: N80 Purge valve replacement
Hi,
Not sure if you have resolved your issue but wanted to share my experience on it. I also used to have the same DTC (P0441):
001089 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 254
Mileage: 20912 km
Time Indication: 0
Date: 2000.00.00
Time: 10:39:16
So I decided to replace the N80 valve: (pic 1)
This replacement includes the valve's right vent hose to a new one with new routing, which improves EVAP system performance; so in total I used the following service parts: (pic 2)
- N80 valve P/N 06E906517A
- New-design vent hose P/N 8P0133781B
- Clamps P/N N10199201 (3-pcs)
I needed a thin flat screwdriver and needle pliers. A carpenter pliers were also useful to tight the clamps: (pic 3)
The work was fairly easy. As you may know one must remove the sound absorber panel (I asked for someone else's help since it was too hard to remove mine by myself) TIP: Heat up the engine to ease its removal.
After disconnecting the valve harness and the plastic hose right above the valve, I used the flat screwdriver and needle pliers to disengage the clamps, being careful not to damage the fuel steel tube and valve's left short hose: (pic 4)
I finally connected the new hose and valve as per initial position and maked sure to tight the clamps well. So I got something like this: (pic 5)
I noticed a little increase in power and have not had the DTC since then; hope it continues like that.
Hope it helps!
