tomshouse516
tomtomtomotomtomtomtomtom
- Newtown PA
- 09 GT1
I will update this thread with any and all info I learn from the install as well as pictures, measurments and preformance reviews.
I have one set of 18z calipers.One friend have one set of new 345mm R32 front discs.Will this work?Because everywhere i see the ML type discs.
Thanks
George
Great work there, this kit sounds like one of the better DIY budget kits out there
I have about $830 into my entire front setup with all brand new parts
Can someone tell me what Porsche these are from?
They are 4 pot front and back.(large pistons not the smaller ones) I think cayenne but could be mistsken .
Picked these up for 250€ so going to try make them work.
Just happened to come across this thread while doing some research.Super old thread bump. I ended up using the 17z setup mentioned here with all correct hardware and hub rings. I'm having an issue with the rotors. They are ML350 rotors but they contact the ball joint and outer pad stop pins in the caliper. I for the life of me cannot figure out what the issue is, it's as if the rotors are just too thick since there's no way to move them inboard or outboard on the hub and it's contacting on both sides. Anyone have any ideas!? Any help will be appreciated.
