How-to Porsche Cayenne / VW Toureg / Audi Q7 Brembo brakes.
TXBDan
Boston, MA
Do you guys know the weights of the GTI rotor, R32/R rotor, and ML350 330mm rotor?
tomshouse516
tomtomtomotomtomtomtomtom
Newtown PA
09 GT1
GTI are 312mm - 18.5 lbs (used)
ML350 are 330mm - 26.5 lbs
.:R are 345mm - 27.25 lbs
GL450 are 350mm - 29.5 lbs
+8lbs from stock gti rotors but the calipers should be about 5lbs lighter
-.75lbs from .:R rotor plus a larger drop in caliper weight.
Pikeville, KY
Subaru
GTI are 312mm - 18.5lbs (used)
ML350 are 330mm - 26.5lbs
.:R are 345mm - 27.25lbs
do you know what rabbits weight? id like to have a set for the drag strip and im just curious now
phillip1978
VIC AUSTRALIA
I only did a quick search on google
"hubcentric rings"
There seems to be heaps of companies out there that do this, i am bit skeptical of rings made of plastic aswell but i am sure there should be more companies out there that make rings from steel or aluminium alloy
