TXBDan
- Boston, MA
Do you guys know the weights of the GTI rotor, R32/R rotor, and ML350 330mm rotor?
GTI are 312mm - 18.5lbs (used)
ML350 are 330mm - 26.5lbs
.:R are 345mm - 27.25lbs
+8lbs from stock gti rotors but the calipers should be about 5lbs lighter
-.75lbs from .:R rotor plus a larger drop in caliper weight.
do you know what rabbits weight? id like to have a set for the drag strip and im just curious now
the hub diameter that the wheel sits on is different than the diameter that the rotor sits on. You need a 67-65mm ring.
I am about to order up the last few items for my setup this week.
Yea they are super cheap for the set like $20 or something, nbd.
I need to order my .:R rear brakes and I will be all set.
