The EVAP failures vary from cracks in the canister(not likely) to cracked tubing or a failed purge valve(shown in the first vid). The first vid confirms the issue with the car he has there had a compound issue or more than one problem...and this happens often.
This guy isn't familiar with our 2.0t FSI but he's good at discovering issues. In this, he shows ways to test the common possibilities. He doesn't understand when you clear codes is when you see a jump in the STFT and then it corrects and recalibrates to appear to be fine at idle. You can watch the whole thing which includes smoke testing and a few other checks he performed...or; from about 46 minutes on is a good place to start;
Here's the clear codes and how the idle trims jump and then reset;
