"hiccuping" at speed and P2181 Code
GTAye
The Dirty Jersey
09 GTI experiencing a "hiccup" or "miss" when above 40 mph. Seems to happen mostly when at cruising speed but I can accelerate through it while it's happening. It is very hit or miss. Some trips it doesn't happen at all.
I do have the P2181 coolant system performance code for my car running too cool but I have yet to see the hiccuping being related to this code.
I did hook it up to OBDFusion and while my dash temp reports 190° , OBD said my temp was 170°.
Could running cool possibly cause a hiccuping / missing issue?
Sent from my Pixel 3a XL using Tapatalk
707Stang
I'm Hella From Nor*Cal
Nor*Cal
Hard to say it will definitely cause it but I’ve never seen it. Thermostats failing open typically cause a rich running condition but you’d have to really be overfueling to cause a miss.
