Hesitation
Ever since going GIAC extreme, when i give full throttle ill have this hesitation/vibration (sounds like de-de-de-de inside the cabin) before it finally sling shots. This is most apparent around 2000-3000rpms. When i have the windows down with a car next to me and it occurs, i hear the intake going "ppssh psshh ppshhh" then takes off. I'm thinking it could be because i am running stock G DV so i will be upgrading to the AWE one sometime this week. Anyone experience this or know what it could be?
Valve Springs
Basically i have a later k04 stock engine in my car and i have read the UK forums and they have found that many of the newer S3s, TTS's, Leo Cupras and MKV GTI's even have the common misfire in cylinder 3.
I get the misfire CEL when i push the car to redline which results in the CEL flashing or staying lit. Spark plugs have been replaced and coil pack has been checked and both ok. I further read on the UK forum that it could either be down to the the downpipe (since stock is very restrictive) or the valve springs.
Now i have already replaced my stock downpipe with a custom 3 inch downpipe with 200 cel and all was well for along time until the CEL appeared again on full throttle and on the dyno. So i am almost 100% convinced its the valve springs. From the info in the UK forum they say that if you have yellow/white springs that they are too soft and these cause the CELs whilst if you have the blue/yellow springs youre fine.
Theres no chance VW service will help since i have many mods and the CEL doesn't come during stock mode as well. So question is has anyone had experience on replacing these springs? How hard and long is the process? i will most likely have to go to my mechanic to get this done but all your help would be greatly appreciated.
Thanks!
Valve Springs
Thanks!
