HELP!! Electric auxiliary cooling pump not working
Chumeta
Vitoria-España
I don´t get any fault with the vcds, but when I stop it does not work as it did before. I have changed the pump and it still does not work. I´m scared because your mission is to cool the turbo when stopping. Any ideas? Thanks. Sorry for my English
GTI's
MD
I have done test with the vcds and it does it well as if it works correctly, but it does not work or give error code. thanks
So when you did the output test for the coolant pump from the Ecu did you hear or feel the pump working. The pump only uses a ground and power through a relay controlled by Ecu. You did not state what car you are working on but you need to find the wiring diagrams for it and see how the coolant punp is wired and what fuses & relays etc are used in the circuit.
GTI's
MD
EA113 engine
To prevent carbon build-up on the turbine shaft in the turbocharger, an auxiliary coolant pump(V50) provides additional coolant circulation for a certain time after the engine is shut off hot.
EA888gen1
After-Run Coolant Pump V51 protects the turbocharger bearings from overheating after engine shut-off. The pump is activated by the engine control module based on programmed characteristic maps.
Chumeta
Vitoria-España
No, when I do the output test for the pump I hear only the relay, but the pump does not work. The vcds does not detect that it does not work and does not fail, but it does not work
Chumeta
Vitoria-España
Thanks for your help, do you have anybody electrical diagram of operation, fuse or any other information? Remember to change the pump and it still won't work. Thank you
GTI's
MD
If you are hearing the relay in the fuse/relay box buy battery you will have to check if you have power at the relay terminal and see if the wiring that the power goes out on from the relay is functional and that you also have a good ground at the plug for coolant pump.
Sent you a PM for wiring diagrams
