Headlight Adjustment not going exactly how VCDS says it should...I recently installed a new headlight assembly and finally drove at night and the left that I just replaced is lower than the right.
....but when I get to the step; Scroll up to Group 002. ....I cannot use the up or down buttons as they are dimmed. When I enter 2, it says error. Finally, and doing the exact same thing there was no error in Group 002. I hope it is learned but who knows until I drive at night again.
Anyhow, just wanted to see what others may have run into regarding this. I see there is a warning related to lowered blah blah blah on the VCDS site. So yes, mine is low and the headlight level sensor linkages are not incorrect. They may however be bottomed out. Although it never had an issue auto-leveling before. Just curious why the VCDS steps do not go as stated.
All ears.....
I follow these instructions;
There are certain test conditions that must be met before doing this procedure:
Procedure for Aligning Xenon Headlamps:
- Vehicle must be parked on level ground and "settled" on its suspension
- Parking brake should be OFF
- Ignition should be in the "On" position
- Headlamps should be "Off"
[Select]
[55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
[Basic Settings - 04]
Group 001
[Go!]
Wait at least 20 seconds for the headlamp motors to move. The headlamps are now in their adjustment position. Turn on headlights. Adjust them via their manual adjusting screws as referenced against a suitable aiming target.
Scroll up to Group 002. The Xenon Range controller has now learned this position as its Home position.
Click the [Done, Go Back] button and you're all set.
All ears.....
