Golf MkV clapping noise
MiloradJ
Bosnia and Herzegovina
Golf MKV
Hello guys, my first post here... I'm having problem with my golf mk5, 1.9 TDI, 77kW, manual. Happened all of a sudden this morning, clapping noise when not accelerating, doesn' have any connection with pressing the clutch pedal or engine rpm. Here is the video:
MiloradJ
Golf MKV
I found what it was... Right front tire wasn't properly tightened so the screws evenly unscrewed itself during drive. It is a bizzare and dangerous mistake, but luckily repaired it. It is not possible to check whether the tire is loose until you lift the car up.
MagicMK
PA
How did that happen? Do you have a torque wrench?
vwengineer
Switzerland
I would inspect the threads carefully. A friend of mine lost a tire like this, probably that the tire was not tight from the begging and bit by bit it destroyed all the threads (he also had a noise). Luckily for him it happened on a parking lot but the front of the car was destroyed
