GHL TBE = P0420???
vlkswgnbgmn66
Fresno, CA
Fahrenheit GTI #473
So as I stated in anouther thread my CEL came on last night. Took it to my buddy at the dealer and he gave me a print out and the code that was stored was P0420 - cat not efficient enough. So I called GHL and they basically told me that I need a chip because its a high-flow cat. My buddy uses high flow cats on cars all day at his muffler shop and has never had a problem using them and setting a CEL. Has anyone else experienced the same problem with their high-flow cat and no chip???:iono:
HoldDaMayo
Leaner and Meaner
Temecula, CA
2007 GTI UG 5 Door
there are VERY few DP's that don't cause a CEL... I think the lesson learned here is get chip'd before you do a DP or TBE.
The AWE DP or TBE doesn't cause a CEL, I know there are a few others, but being the AWE fanboy I am, I'll only mention AWE... AWE...
PS... AWE.
dpham00
Modérateur Emeritus
Los Angeles, CA
for a car with just a tbe, and otherwise stock, you need to either get a spacer like the wayne angle block, or buy certain cats that don't throw a CEL with an otherwise stock car.
this is also discussed in my sig.
vlkswgnbgmn66
Fresno, CA
Fahrenheit GTI #473
vlkswgnbgmn66
Fresno, CA
Fahrenheit GTI #473
Found out today that the auto-zone fix won't work. Mk4 O2 sensors are smaller(the tip). Ours would have to be drilled out to approximately 9/16" which doesn't work with those "help" parts cause the wall get too thin and breaks. Now I gotta get ahold of wayne and see if he makes a version for our cars...
rsquadGTi
Most Hated Hater...
Toronto
W204 C63/Porsche 911
Have the GHL TBE... After 2 months of running the car the CEL came on. Same code as you. Reset it with the Vag-Com and haven't' seen it since. I'm not chipped.... yet.
vlkswgnbgmn66
Fresno, CA
Fahrenheit GTI #473
Yeah I'm gonna make one like Dan's. I don't wanna chip it just yet (funds and other things I wanna do first) I have the parts and tools. Plus that thing looks sweet and like it will do the job perfectly!!!:bow:
rsquadGTi
Most Hated Hater...
Toronto
you could use an o2L
Hi Dan,
Will there be any adverse effects of fooling the rear O2 sensor? Get any lean or rich condition? I was told in some rare cases this could occur?
