Changed the oil in the GTI yesterday at 112,500 miles... However, it seems I opened and closed the hood 1 too many times and caused a super hidden electrical short which threw 4 fault codes, disabled airbags, blew the heated seat fuse, and disabled the A/C compressor....
I just wanted to post these codes if someone ever searches for them and can't find the root cause.
I knew this hood hinge wire harness and wiper fluid tube route had been bending awkwardly for a while cause i'd get a click sound when i closed the hood sometimes, but NEVER thought it would lead to all these fault codes!
Address 01: Engine (CBF)
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
Address 03: ABS Brakes
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 15: Airbags
02511 - Control Module for Seat Occupied Recognition (J706)
012 - Electrical Fault in Circuit - MIL ON
Credit goes to user relumalutan on TDIClub Forums for knowing a short within this harness could throw the Airbag / Seat Occupied Recognition code.
http://forums.tdiclub.com/showthread.php?t=483831
So I separated the wires as my picture shows, then electrical taped each individually to prevent another short, then cleared all the codes with VAGCOM and replaced the #4 mini 5-amp fuse for the Heated Seats.
I got sooooo lucky finding that thread on TDIClub Forums! :thumbup:
Really hope this info helps someone in the future...
Address 15: Airbags
