Full List of TSBs' For MKV (GTI,GLI,Jetta,Rabbit,2.0TFSI,2.5)
MagicChic
GolfMKV Madame
Quakertown, PA
2006 VW GTI
Thank you!
My mechanic looked into it and he asked their rep about it. The rep said he had seen condensation get in the rear leveling sensors, which was causing the headlights to bounce, but my mechanic looked at it for corrosion and condensation, found nothing, but cleaned it anyway. But it still hasn't helped. Everything in the housing is tight, and the housing itself is fine too, but we just can't figure it out. I think they should just give me a new bulb and see if that works.
bmp_gti
Houston
Hi. I am in need of
87-07-07 HVAC, Musty Odor (May 10, 2007)
91-07-09 Radio, Sound System, IPod Adaptor Kit (Aug. 2, 2007)
gerrits @ gmail.com
Thanks
gtimkvftw
18dogbaby
Mississauga, Ontario
2008 BMP GTI 6MT
If someone could send me these please. I'd appreciate it, thanks.
92-06-07 Washer Jets (Front or Rear), Restricted (Dec. 11, 2006)
20-07-07 Fuel Lines, Rattle (May 3, 2007)
sloMk5
___________
Tampa
2007 GTI
Thanks for posting this agpatel.
Does anyone know where I can find all the PDF files? I've been looking and I can find some here and there, but is there somewhere that has them all in one place?
tavito_pr
Mountain Top, PA
Alltrack/GSW/CaVRio
when you get a chance would you be able to send me these..
37-07-09 Launch Control Program, Vehicles with DSG Transmissions (March 20, 2007)
37-07-18 Transmission, Knocking Noise Under Load (August 23, 2007)
to gusta.rodz@gmail.com
thanks
agpatel
Touring Car Champion
Greensboro, NC
2006 GTI MkV
Like i said above I no longer have access to TSB's. Sorry to all PM's that I didnt reply back to I have been really busy with classes this semester.
agpatel
Greensboro, NC
2006 GTI MkV
Some New TSB That have been issued:
(I can not post the TSB's on the site nor send them but i can tell you what the tsb is about/about what the fix would be)
*Note* I may not be able to respond fast but i will try to respond as fast as i can*
Please try to ask for only the newer ones, older ones you can find info on the boards if searched. Thanks
  • 01-08-36 Software Version Management (December 10, 2008)
  • 57-08-15 Front Door Deformed by Ice (December 10, 2008)
  • 17-08-03 Oil Consumption Measurement (December 10, 2008)
  • 66-08-02 Door Mirror, Electric, Loose or Folding Function Incorrect (December 2, 2008)
  • 19-08-01 Cooling Fan Continues to Run after Switching Engine OFF (December 8, 2008) (TSI MOTOR)
ACDCFAN
Perth, WA AU
Hi all
this is my first post in these forums, but I am active in the forums in Oz. :headbang:
I was wondering if OP can email me TSB 87-07-09 A/C, No or Low Output (August 8, 2007). :bow:
I have a feeling, you know the feeling you get when you know something ain't right but you can't put your finger on it:mad:, that my aircon is not working properly.
Dealer has checked it and could not find anything wrong with it, but it seems that it does not blow as cold air as if you're driving.
When the car was new and up to a year old there was no difference at all but now after 2 years it seems that when temps hit here around 45 it takes about 15 min before you notice drop in the temp in the car. ( car parked in the shade with windows open)
rstkpetrovic@gmail.com
panzer
VA
Here is a TSB for the airbag light in addition to the seat wiring harness.
01-08-07 Update Pod Module
Don't know if this is the correct wording for the title of it. The service writer just gave me the number and this description. They had to reflash to module to clear the DTC and light.
Panzer
'08 SG 5spd
linux_guy
Saint Louis
GTI
Sry I already messaged you without seeing that you no longer have access to TSB's..
Well if anyone gets their hand on following:
91-07-10 Radio, Panasonic Premium Sound System, Bass Flare (Aug. 17, 2007)
91-07-12 Radio, Navigation System, Performance (Aug. 17, 2007)
90-07-04 Instrument Cluster, Incorrect Adaptation when using Brand CD 10.76 (U.S. ONLY) (June 1, 2007)
97-07-04 Radio Speaker, Front Door, Inoperative (June 13, 2007)
00-07-06 PDI - Radio, Anti-Theft Radio Security Code Not Equipped (Apr. 11, 2007)
44-06-10 Tire Pressure Monitoring System (TPMS), System Overview (Nov. 21, 2006)
48-06-01 Driver Steering Recommendation (DSR) Activation and Software Programming for DTCs (February 17, 2006)
48-06-02 Steering System Adaptation Requirement After Replacement Part Installation. (4/28/2006)
46-07-0190-07-02 Multi-function Trip Computer, Accuracy Concerns with Average Trip Fuel Consumption Calculation (Mar. 23, 2007)
90-07-03 Speedometer, Indicated Speed is Greater than Actual Vehicle Speed (May 24, 2007)
91-06-03 Radio, Panasonic Premium 7 Amp Clipping (Jul. 28, 2006)
91-06-05 Radio, Navigation System, Operating Errors (Aug. 29, 2006)
91-06-10 Radio, Premium Sound System (Panasonic) Sound Inconsistent (Nov. 6, 2006)
91-06-11 Radio, Premium Sound System (Panasonic) "NO SAT" Displayed (Nov. 6, 2006)
91-07-01 Use of Novelty Compact Discs in Compact Disc (CD) Players (Jan. 24, 2007)
91-06-03 Radio Panasonic Premium 7, ecretage de l'amplificateur (28 juillet 2006)
91-06-05 Radio, système de navigation, erreurs de fonctionnement (Aug. 29, 2006)
91-07-06 Radio, Reception Diagnosis (May 9, 2007)
92-06-03 92-06-07 Washer Jets (Front or Rear), Restricted (Dec. 11, 2006)
Please send me the TSB's to alan@linuxdonkey.com
TASOS
Tuning addict
Athens Greece
Hi
If somebody has TSB-01-08-12 ... please pm or e-mail me.
the intake flap motor or intake manifold runner position sensor g336 may be inoperative
Thanks
