agpatel
Touring Car Champion
- Greensboro, NC
- 2006 GTI MkV
I do not have accesses to TSBs anymore. Sorry.
All The TSB Out for the MKV (GTI For the most part but they go for most all MKV's)
I will update as they come in, please PM me if you would like a certain TSB w/ your email, i will post it in this thread or email it to you.
Please send me the full line of the TSB, example "46-07-01 Brake Disc, Pulsation (June 11, 2007)" Making it easier for me to find it
Please understand i am a full time student and it may take a day for me to send it to you
Update: 8/30
PT01-07-57 Update Programming for ECM Part Number Beginning with 07K (Aug. 24, 2007 )
Update: 8/24
37-07-14 Transmission, Will Not Shift Out of Park (July 30, 2007)
91-07-09 Radio, Sound System, IPod Adaptor Kit (Aug. 2, 2007)
37-07-15 Transmission, Will Not Shift Out of Park (Aug. 3, 2007)
87-07-09 A/C, No or Low Output (August 8, 2007)
00-07-10 PDI - Vehicle Inspection, Protection Removal and Detailing (August 10, 2007)
70-07-06 Interior, Cleaning Tips for Fabrics, Vinyls and Plastics (Aug. 10, 2007)
70-07-07 Interior, Cleaning Tips for Leather Upholstery (Aug. 10, 2007)
94-07-03 License Plate Lights, Water Intrusion (August 13, 2007)
91-07-10 Radio, Panasonic Premium Sound System, Bass Flare (Aug. 17, 2007)
91-07-12 Radio, Navigation System, Performance (Aug. 17, 2007)
34-07-05 Transmission, Manual 6 Speed (MQ350), Knocking Noise under Load (Aug. 22, 2007)
87-07-10 Air Conditioning Inoperative (Aug. 23, 2007)
37-07-18 Transmission, Knocking Noise Under Load (August 23, 2007)
Update: (07/11/07)
46-07-03 Brake Disc, Pulsation (July 6, 2007)
01-07-54 Engine Control Module (ECM), DO NOT Replace for These Diagnostic Trouble Codes (DTCs) (July 10, 2007)
Update (7/8/07)
37-07-11 Transmission, Automatic Transmission Leaking Fluid (July 5, 2007)
90-07-04 Instrument Cluster, Incorrect Adaptation when using Brand CD 10.76 (U.S. ONLY) (June 1, 2007)
27-07-07 Battery, Discharged and Faulty Comfort Functions (June 8, 2007)
46-07-02 Customer States Vibration When Braking (June 11, 2007)
97-07-04 Radio Speaker, Front Door, Inoperative (June 13, 2007)
60-07-06 Sunroof and Central Control Module -J393- Diagnosis (June 19, 2007)
15-07-04 MIL ON, DTC P0087, P1093 or P2293 Stored in ECM Fault Memory (June 29, 2007)
20-07-09 MIL ON, DTCs P0442, P0455, P0456 or P2404 Stored in ECM Fault Memory, No Leaks Present (June 29, 2007)
00-06-01 Maintenance Schedule, Service Reminder Indicator Reset (Jan. 17, 2006)
00-07-01 Sealants, Liquid Gaskets and Lubricants Containing Silicone (Jan. 19, 2007)
00-07-06 PDI - Radio, Anti-Theft Radio Security Code Not Equipped (Apr. 11, 2007)
01-06-15 Engine, Cranks Intermittently or No Crank (Sep. 19, 2006)
01-06-24 MIL ON - Misfire DTC Stored After Cold Start (Dec. 5, 2006)
01-07-01 DTCs 00545 and 00638 Stored in DTC Memory (Jan. 8, 2007)
01-07-03 MIL ON, DTC P0299 Charge Pressure Control Negative Deviation Stored in ECM (Jan. 11, 2007)
01-07-02 DTC's P1297 (17705) or P1557 (17965) Stored in DTC Memory (Jan. 11, 2007)
01-07-30 Generic OBD II Scan Tool Displays Incorrect Values (Mar. 9, 2007)
01-07-33 Generic OBD II Scan Tool Not Displaying DTC P1624, P1847 (Apr. 5, 2007)
01-07-35 Software Version Management (Apr. 11, 2007)
01-07-36 RVU - Update Programming to Eliminate DTC P0601 Stored in DTC Memory (OY) (April 13, 2007)
01-07-39 Gasoline Quality (April 27, 2007)
01-07-40 Fuel, Poor Quality (May 1, 2007)
01-07-48 Update Programming, MIL ON, DTC P0011, P000A Stored in ECM Fault Memory (May 15, 2007)
PT01-07-21 RVU - Update Programming to Eliminate DTC P0601 Stored in DTC Memory (OY) (Feb. 13, 2007)
PT01-07-48 Update Programming, MIL ON, DTC P0011, P000A Stored in ECM Fault Memory (May 15, 2007)
10-07-01 Engine Replacement, Checking for Debris Lodged in Transferred Assemblies (Feb. 20, 2007)
17-06-01 Engine Oils Which Meet Volkswagen Oil Quality Standards VW 502 00 and VW 505 01 (Sept. 12, 2006)
17-07-05 Oil Pan Drain Plug, Cleaning Threads on Plug and Oil Pan When Changing Oil (Mar. 2, 2007)
17-07-06 Engine Oil, Volkswagen Oil Quality Standard VW 505 01 Requirement (Mar. 7, 2007)
20-06-01 Fuel Tanks Removed from Vehicles, Neutralizing Fuel (February 17, 2006)
20-07-01 Diesel Fuel, Cold Weather Conditioning for Driving at Temperatures below 0°C (32°F) (Jan. 18, 2007)
20-07-06 Evaporative Emission (EVAP) System, Diagnostic Trouble Code Diagnosis (April 4, 2007)
20-07-07 Fuel Lines, Rattle (May 3, 2007)
24-06-01 Malfunction Indicator Lamp (MIL) Illuminated, DTCs P0171, P2187 Stored in ECM Memory (Nov. 8, 2006)
24-07-06 Intake System, Checking For Leaks Using the VAG Diagnostic Tool (Feb. 6, 2007)
26-07-01 Catalytic Converter, Replacement Guidelines (Feb. 9, 2007)
27-06-03 Battery, Testing, Charging Using Midtronics MCR340V Battery Analyzer or InCharge 940 (INC-940) Battery Charging Station (Oct. 6, 2006)
34-06-04 Customer States Gear Selection Indicator in Instrument Cluster Flashes (Aug. 17, 2006)
35-06-01 Direct Shift Gearbox (DSG), Momentary Delay When Accelerating (March 14, 2006)
37-06-07 Transmission, DSG*, Intermittent Engagement Delay Upon Acceleration (Dec. 22, 2006)
37-07-09 Launch Control Program, Vehicles with DSG Transmissions (March 20, 2007)
44-06-10 Tire Pressure Monitoring System (TPMS), System Overview (Nov. 21, 2006)
48-06-01 Driver Steering Recommendation (DSR) Activation and Software Programming for DTCs (February 17, 2006)
48-06-02 Steering System Adaptation Requirement After Replacement Part Installation. (4/28/2006)
57-06-05 Front Door Control Modules, Inoperative (Dec. 11, 2006)
57-07-04 Battery, Remote Key Verification (Mar. 22, 2007)
57-07-05 Front Door Deformed by Ice (April 23, 2007)
64-06-09 Heated Rear Window, One or More Lines Are Inoperative (Sep. 21, 2006)
68-07-04 Headliner, Grab Handle & Sun Visor, Installation Tips (Feb. 14, 2007)
69-06-03 Module, Airbag, Color Code Identification and Coding (February 3, 2006)
69-06-07 Airbag / Pyrotechnic Safety Belt Deployment Inquiries (Sept. 26, 2006)
69-07-01 2005494 Advanced Airbag System Description, Passenger Side Airbag (Feb. 15, 2007)
69-07-03 Igniter, Side Airbag, Diagnostic Trouble Code(s) Stored in DTC Memory (Mar. 23, 2007)
72-06-02 Front Seat Slides Hard or is Noisy (2 door only) (Oct. 20, 2006)
87-07-03 2013314 Air Conditioning Inoperative (Feb. 15, 2007)
87-07-07 HVAC, Musty Odor (May 10, 2007)
90-07-02 Multi-function Trip Computer, Accuracy Concerns with Average Trip Fuel Consumption Calculation (Mar. 23, 2007)
90-07-03 Speedometer, Indicated Speed is Greater than Actual Vehicle Speed (May 24, 2007)
91-06-03 Radio, Panasonic Premium 7 Amp Clipping (Jul. 28, 2006)
91-06-05 Radio, Navigation System, Operating Errors (Aug. 29, 2006)
91-06-10 Radio, Premium Sound System (Panasonic) Sound Inconsistent (Nov. 6, 2006)
91-06-11 Radio, Premium Sound System (Panasonic) "NO SAT" Displayed (Nov. 6, 2006)
91-07-01 Use of Novelty Compact Discs in Compact Disc (CD) Players (Jan. 24, 2007)
91-06-03 Radio Panasonic Premium 7, ecretage de l'amplificateur (28 juillet 2006)
91-06-05 Radio, système de navigation, erreurs de fonctionnement (Aug. 29, 2006)
91-07-06 Radio, Reception Diagnosis (May 9, 2007)
92-06-03 Customer States "Windshield Wipers Make One Intermittent Sweep Across Windshield While Driving" (May 19, 2006)
92-06-07 Washer Jets (Front or Rear), Restricted (Dec. 11, 2006)
94-06-01 Day Time Running Lamps Switched ON Prior to Delivery (January 27, 2006)
94-06-02 Exterior Lights, Moisture Accumulation (Feb. 27, 2006)
96-07-01 Driver Door, Central Locking -Safe- Indicator Lamp -K133- Remains Illuminated (May 25, 2007)
Update: 8/30
Update: 8/24
Update: (07/11/07)
Update (7/8/07)
