Just wondering what the difference is between the H pump and the B pump for the 2.0 FSI, and can can you get a B pump upgraded from APR and put it on a GTI that came with an H pump?
The H has a shrader valve on it and the B does not. Does this make a difference. Can I take the part with the shrader valve off my H pump and put it on the B pump after I get it back from APR? It is nice to have the shrader valve to release the pressure. Or does it matter
Ultimately the pressure and the flow should be the same between the B and the H after you get either back from APR as they change the internals, so I am basically sending the used pump that I got as a core. They will only be using the housing.
Sorry if I sound stupid, just don't want to spend the money on something I cannot use.
